Objet : Discussion list for Belenios
Archives de la liste
- From: Véronique Cortier <veronique.cortier AT loria.fr>
- To: Tejaswi Nadahalli <nadahalli AT gmail.com>
- Cc: belenios-discuss AT lists.gforge.inria.fr
- Subject: Re: [Belenios-discuss] Belenios Re-randomization primitive code examples
- Date: Tue, 13 Aug 2019 21:00:57 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/belenios-discuss/>
- List-id: Discussion list for Belenios <belenios-discuss.lists.gforge.inria.fr>
Dear Tejaswi,
I think there is some confusion here. BeleniosVS and BeleniosRF are
variants of Belenios that explore what could be done in the future.
There is no well developed codes associated to these variants and no
concrete plan for integrating them to our code base.
Instead, our voting platform Belenios corresponds to the implementation
of the Belenios protocol, described for example here:
https://hal.inria.fr/hal-02066930/document
Btw, this mailing-list is primarily intended to discuss about Belenios
(but your questions are still welcome!).
This explains why you don't find any re-randomization primitive in our
code base, there is none.
Kind regards,
Veronique.
Le 13/08/2019 à 15:05, Tejaswi Nadahalli a écrit :
> I am going through the code
> <https://gitlab.inria.fr/belenios/belenios> looking to see if I can run
> the re-randomization primitive on the command line. If I find the
> library code, I can write some command line harnesses to make it work.
> But given that I am not an OCaml expert, I have no idea where to search
> for it - my initial browsing has yielded nothing. Does anyone know where
> the re-randomization library is in the code?
> _______________________________________________
> Belenios-discuss mailing list
> Belenios-discuss AT lists.gforge.inria.fr
> https://lists.gforge.inria.fr/mailman/listinfo/belenios-discuss
- [Belenios-discuss] Belenios Re-randomization primitive code examples, Tejaswi Nadahalli, 13/08/2019
- Re: [Belenios-discuss] Belenios Re-randomization primitive code examples, Véronique Cortier, 13/08/2019
