Accéder au contenu.
Menu Sympa
belenios-discuss - [Belenios-discuss] L'organisateur d'un vote peut-il déchiffrer les votes individuels et l'urne ?
Objet : Discussion list for Belenios
Archives de la liste
Chronologique Discussions
  • From: Hery Rakotoarisoa <Hery.Rakotoarisoa AT uvsq.fr>
  • To: belenios-discuss AT lists.gforge.inria.fr
  • Subject: [Belenios-discuss] L'organisateur d'un vote peut-il déchiffrer les votes individuels et l'urne ?
  • Date: Mon, 04 May 2020 13:01:15 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=Hery.Rakotoarisoa AT uvsq.fr; spf=Pass smtp.mailfrom=Hery.Rakotoarisoa AT uvsq.fr; spf=Pass smtp.helo=postmaster AT soleil.uvsq.fr
  • Dkim-filter: OpenDKIM Filter v2.11.0 smtps.uvsq.fr 56EE04103F20
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/belenios-discuss/>
  • List-id: Discussion list for Belenios <belenios-discuss.lists.gforge.inria.fr>
  • Organization: Université de Versailles - Saint-Quentin-en-Yvelines
Bonjour,
Il est conseillé de déléguer l'opération de génération et d'envoi par
mail des codes de vote (credentials) à un tiers externe, ce qui permet
plus de sécurité vis à vis du serveur. Il n'est pas toujours possible
de ce faire, et je n'ai pas trouvé dans les documents le niveau de
risque sur ce point par rapport à l'organisateur du vote.
En effet, lorsqu'on choisit de laisser quand-même cette opération au
serveur Belenios du LORIA, l'organisateur a la possibilité de
télécharger ces codes pour pouvoir les renvoyer aux votants par la
suite si besoin.
Est-ce que l'organisateur, ayant ces codes, peut totalement fausser ou
rompre le secret:
- déchiffrer les votes individuels et avoir donc connaissance de ces
votes ?
- voter à la place des individus, et donc "bourrer" l'urne ? Il faut
quand même l'authentification pour ce faire à priori.
Si oui, cela est-il à la portée simple des moyens actuels d'une
personne physique ?
Ou nécessite des moyens lourds/puissants de chiffrement/déchiffrement,
auquel cas le risque pourrait être accepté pour certaines élections ?
Je vous remercie par avance de votre réponse, pour me rassurer, ou non
Bien cordialement,
PS: Désolé de l'envoi multiple par mail et une autre liste.
Hery Rakotoarisoa
DGS-A - Directeur du SI et du Développement Numérique
Université de Versailles Saint-Quentin-en-Yvelines
55, Avenue de Paris - 78035 Versailles Cedex
E-Mail: Hery.Rakotoarisoa AT uvsq.fr - Tél.: +33 1 39 25 78 81
Haut de le page
