Objet : Discussion list for Belenios
Archives de la liste
- From: "belenios AT arc-occitanie.fr" <belenios AT arc-occitanie.fr>
- To: belenios-discuss AT lists.gforge.inria.fr
- Subject: [Belenios-discuss] Belenios - Refus de dépôt de bulletin dans l'urne
- Date: Wed, 30 Sep 2020 20:40:03 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=belenios AT arc-occitanie.fr; spf=Pass smtp.mailfrom=belenios AT arc-occitanie.fr; spf=None smtp.helo=postmaster AT 7.mo173.mail-out.ovh.net
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/belenios-discuss/>
- List-id: Discussion list for Belenios <belenios-discuss.lists.gforge.inria.fr>
- Organization: Arc-Occitanie
Bonjour,
à la suite d'un vote test, un électeur rapporte que le clic sur
"je dépose mon bulletin dans l'urne"
lui a été refusé avec le message "électeur invalide", bien qu'ayant introduit son code vote, puis son mot de passe d'authentification.
Dans cette configuration, l'électeur disposant de son code bulletin et du mot de passe de validation ne peut donc voter.
NB: il s'agit d'un test où chaque électeur dispose de 2 votes adressés via 2 courriels de la forme
<prenom.nom1 AT arc-occitanie.fr> et <prenom.nom2 AT arc-occitanie.fr> pour envoyer le "bulletin1", "mot de passe1" et "bulletin2", "mot de passe2".
Dans les tests de que j'ai effectués, utiliser le "mot de passe2" pour le "bulletin 1" conduit à "Authentification failed". La page du clic de confirmation "je dépose mon bulletin dans l'urne" n'est pas accessible en cas d'inversion de mot de passe.
Le blocage peut-il provenir après plusieurs tentatives infructueuses, même si le "mot de passe1" est enfin bien utilisé pour le "bulletin1"?
PS: il s'agit d'un vote test pour préparer un vote plural où chaque électeur dispose d'un nombre N de voix pour représenter son association (1<=N<=11). Chaque électeur vote donc N fois avec N bulletins envoyés par N courriels.
Cordialement,
Pierre Peruzzetto
https://arc-occitanie.fr
- [Belenios-discuss] Belenios - Refus de dépôt de bulletin dans l'urne, belenios AT arc-occitanie.fr, 30/09/2020
