Objet : Discussion list for Belenios
Archives de la liste
- From: Stephane Lebegue <stephane.lebegue AT univ-littoral.fr>
- To: belenios-discuss AT inria.fr
- Cc: Frédéric Dooremont <frederic.dooremont AT univ-littoral.fr>
- Subject: [belenios-discuss] Fwd: Test_Belenios_v1.13
- Date: Mon, 25 Jan 2021 14:08:00 +0100 (CET)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=stephane.lebegue AT univ-littoral.fr; spf=Pass smtp.mailfrom=lebegue AT univ-littoral.fr; spf=None smtp.helo=postmaster AT zmmta2.univ-littoral.fr
- Dkim-filter: OpenDKIM Filter v2.9.2 zmmta2.univ-littoral.fr 4275B137F98
- Ironport-phdr: 9a23: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
Bonjour,
Après compilation de la version 1.13 de Belenios, les scripts de tests (valeurs par défaut) renvoient des erreurs de "ResourceWarning" exemples cf ci-dessous.
Tests avec python tests/selenium/test_scenario_1.py et python tests/selenium/test_scenario_2.py
Specs de la VM Proxmox :
- VCpus : 2 sockets - 4 cores
- RAM : 4 - 8 Go Balloning
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 10 (buster)
Release: 10
Codename: buster
Release: 10
Codename: buster
(venv) ipm@belenios-113:~/belenios-1.13$ python --version
Python 3.7.3
Python 3.7.3
Vous remerciant pour vos éléments de réponses.
Bien cordialement.
/usr/lib/python3.7/copy.py:263: ResourceWarning: unclosed <socket.socket fd=8, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=6, laddr=('127.0.0.1', 55288), raddr=('127.0.0.1', 52085)>
memo[id(memo)].append(x)
ResourceWarning: Enable tracemalloc to get the object allocation traceback
/home/ipm/belenios-1.13/venv/lib/python3.7/site-packages/urllib3/connection.py:232: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=6, laddr=('127.0.0.1', 50076), raddr=('127.0.0.1', 43713)>
if "user-agent" not in (six.ensure_str(k.lower()) for k in headers):
/home/ipm/belenios-1.13/venv/lib/python3.7/site-packages/urllib3/util/queue.py:13: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=6, laddr=('127.0.0.1', 58990), raddr=('127.0.0.1', 42789)>
self.queue = collections.deque()
/home/ipm/belenios-1.13/venv/lib/python3.7/site-packages/urllib3/util/timeout.py:103: ResourceWarning: unclosed <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=6, laddr=('127.0.0.1', 38548), raddr=('127.0.0.1', 55039)>
self._connect = self._validate_timeout(connect, "connect")
Stéphane Lebègue
Université du Littoral Côte d'Opale
Service Commun du Système d'Information - SCoSI
Pôle IPM : Informatique Pédagogique Multimédia
Tél : 03 21 46 57 75
- [belenios-discuss] Fwd: Test_Belenios_v1.13, Stephane Lebegue, 25/01/2021
- Re: [belenios-discuss] Fwd: Test_Belenios_v1.13, Stéphane Glondu, 25/01/2021
