Accéder au contenu.
Menu Sympa
belenios-discuss - Re: [belenios-discuss] 1.15 deployment image
Objet : Discussion list for Belenios
Archives de la liste
Chronologique Discussions
  • From: Stéphane Glondu <stephane.glondu AT inria.fr>
  • To: Alex Jago <alex.jago AT pirateparty.org.au>
  • Cc: belenios-discuss AT inria.fr
  • Subject: Re: [belenios-discuss] 1.15 deployment image
  • Date: Fri, 2 Jul 2021 08:39:52 +0200
  • Ironport-hdrordr: A9a23:2meOBKPRp48PmsBcTsSjsMiBIKoaSvp037Dk7S9MoG9uA6qlfqeV7Y0mPH7P+VEssR4b6LO90cW7IE80sKQFhbX5Xo3SOTUO2lHJEGgK1+KLqFfd8m/FmNK1vp0MT0ERMrHN5BRB/KTH3DU=
Hi,
I assume you are refering to:
https://gitlab.inria.fr/belenios/belenios/-/tree/master/doc/nspawn
Le 02/07/2021 à 07:45, Alex Jago a écrit :
> The deployment image is meant to be built from within the development
> container, correct?
Yes.
> On my machine I'm finding that `debootstrap` is
> unavailable from within said container.
I don't understand. debootstrap should be installed in that container
(it is done by belenios-stage2.sh). Didn't you get an error while
building the development container? Could you log in to the development
container and build Belenios?
> Otherwise, is this file [1] an equivalent image to what would be created?
> [1] https://files.inria.fr/belenios/belenios-1.15-20210504.squashfs
> <https://files.inria.fr/belenios/belenios-1.15-20210504.squashfs
Yes.
However, a bug (important if you use numeric logins) has been fixed on
the server running at belenios.loria.fr since the release of 1.15. The
current image can be found at:
https://files.inria.fr/belenios/belenios-1.15-4-g03f7478c-20210520.squashfs
Moreover, I am aware of some issues that appeared after the release of
this file so you might not be able to rebuild it now. Please use the
"1.15-updates" (or "stable") branch if you want to build your own image.
Cheers,
Stéphane
Haut de le page
