Objet : Discussion list for Belenios
Archives de la liste
- From: Stéphane Glondu <stephane.glondu AT inria.fr>
- To: HOUART Gerald <Gerald.Houart AT ulb.be>
- Cc: "belenios-discuss AT inria.fr" <belenios-discuss AT inria.fr>
- Subject: Re: [belenios-discuss] CAS and proxy config
- Date: Wed, 27 Oct 2021 13:46:35 +0200
- Ironport-data: A9a23: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
- Ironport-hdrordr: A9a23:4XEBta15UzDIAbWni6AuUwqjBLEkLtp133Aq2lEZdPU1SL37qynApp4mPHPP5Qr5HUtPpTniAtjifZq/z/FICOAqVN/IYOClggqVxepZjbcKtgeQfREWgdQtspuIHZITNDSJNykfsS+s2njcL+od
Le 24/10/2021 à 18:22, HOUART Gerald a écrit :
> After using Belenios (1.13) in a VM under proxmox, I try now to
> integrate it in our cloud infrastructure (stable v1.17).
> My university is using OpenShift (RedHat’s k8s)
> The docker runs on port 8080 on a private network but it is exposed on
> https port to the world
> The problem is then that the CAS return address incorporate :8080 in the
> url and thus generates an error
> I saw in docs that I must use rewrite-prefix but I encounter some
> problems doing it.
> Where may I put the rewrite-prefix directive ?
> Inside CAS <auth> directive ? Just after ?
Just after (i.e. in the <eliom> directive).
Cheers,
Stéphane
- [belenios-discuss] CAS and proxy config, HOUART Gerald, 24/10/2021
- Re: [belenios-discuss] CAS and proxy config, Stéphane Glondu, 27/10/2021
