Objet : Discussion list for Belenios
Archives de la liste
- To: Stéphane Glondu <stephane.glondu AT inria.fr>
- Cc: belenios-discuss AT inria.fr
- Subject: Re: [belenios-discuss] Problème authentification CAS
- Date: Wed, 10 Nov 2021 15:41:29 +0100 (CET)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=fabien.gaydan AT ensad.fr; spf=Pass smtp.mailfrom=fabien.gaydan AT ensad.fr; spf=None smtp.helo=postmaster AT smtpout01-ext2.partage.renater.fr
- Dkim-filter: OpenDKIM Filter v2.10.3 zmtaout03.partage.renater.fr 2F52A4008D
- Ironport-data: A9a23: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
- Ironport-hdrordr: A9a23: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
Bonjour,
Effectivement l'erreur vient de moi, j'ai bien rempli l'information CAS sur la première page de création de l'élection, mais n'ai pas coché la case attenante pensant que c'était automatique.
Pas de souci, j'indique à mes électeurs la procédure via leur identifiant et le code.
On utilisera le CAS la prochaine fois.
Merci à vous,
Fabien Gaydan
Chargé de mission coordination et gouvernance
+33(0)1.42.34.97.29
École nationale supérieure des Arts Décoratifs
31 rue d'Ulm, 75005 Paris
@ecoleartsdecoparis
ensad.fr
+33(0)1.42.34.97.29
@ecoleartsdecoparis
ensad.fr
OOO
OOOOOO OOOOOO OOOOOO
OOOOOOOOOO OOOO OOOOOOOOOO
OOOOOOOOOOOOOOOOOOOOOOOOOO
OOOOOOOOOOOOOO
OOOOOOOO
OOOOOOOOOOOOOO
OOOOOOOO
OOOOOOOOOOOO
OOOOOO
OOOOOO
OOOO
De: "Stéphane Glondu" <stephane.glondu AT inria.fr>
À: "Fabien GAYDAN" <fabien.gaydan AT ensad.fr>
Cc: "belenios-discuss" <belenios-discuss AT inria.fr>
Envoyé: Mercredi 10 Novembre 2021 13:25:30
Objet: Re: [belenios-discuss] Problème authentification CAS
Bonjour,
Le 10/11/2021 à 11:27, Fabien GAYDAN a écrit :
> Au final, j'ai bien un souci.
> En recréant un nouvelle élection, tout fonctionne bien avec notre CAS
> Il semble donc y avoir un problème avec les 4 élections que j'ai créé,
> effectivement au lieu d'aller sur notre page d'authentification CAS, les
> personnes sont redirigés sur une page Belenios /login?service=email
> Pouvez-vous m'aider ?
Je ne trouve sur notre serveur que 4 élections récentes vous appartenant
(et une plus ancienne). Elle sont toutes configurées pour utiliser le
mode d'authentification "email" qui correspond bien à ce que vous
décrivez (un code à usage unique envoyé lors du vote).
Je ne suis pas sûr de vous comprendre quand vous dites "tout fonctionne
bien avec notre CAS"... Quel test avez-vous effectué ? Je n'en trouve
pas trace sur notre serveur...
En tout cas, pour que les utilisateurs s'authentifient avec CAS, il faut
sélectionner le choix idoine (et donner l'adresse du serveur) dans la
première page lors de la création de l'élection.
Cordialement,
Stéphane Glondu
Belenios est un logiciel libre. Vous pouvez nous soutenir en faisant un
don : https://www.belenios.org/donations-fr.html
Cordialement,
Stéphane Glondu
- [belenios-discuss] Problème authentification CAS, Fabien GAYDAN, 10/11/2021
- Re: [belenios-discuss] Problème authentification CAS, Fabien GAYDAN, 10/11/2021
- Re: [belenios-discuss] Problème authentification CAS, Stéphane Glondu, 10/11/2021
