Objet : Discussion list for Belenios
Archives de la liste
- From: Pierre Schweitzer <pierre.schweitzer AT u-bordeaux.fr>
- To: belenios-discuss AT inria.fr
- Subject: [belenios-discuss] Retour d'expérience et suggestions
- Date: Wed, 12 Jan 2022 09:47:09 +0100 (CET)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=pierre.schweitzer AT u-bordeaux.fr; spf=Pass smtp.mailfrom=pierre.schweitzer AT u-bordeaux.fr; spf=None smtp.helo=postmaster AT v-zimmta03.u-bordeaux.fr
- Ironport-data: A9a23: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
- Ironport-hdrordr: A9a23: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
Bonjour,
Tout d'abord merci d'avoir développé et mis à disposition de tous cet outil de vote extrêmement utile, et bonne année à votre équipe également !
Après avoir utilisé Belenios pour organiser des élections au sein de notre unité, je vous partage quelques retours concernant certains détails mineurs qui pourraient peut-être améliorer encore l'expérience des administrateurs et utilisateurs :
1. Les codes de vote sont envoyés dès leur génération
Ceci incite les administrateurs à générer les codes au dernier moment, juste avant de démarrer une élection. Il serait pratique d'avoir l'option de n'envoyer les codes que lorsque l'élection commence.
2. Les codes ne sont plus accessibles une fois l'élection commencée
La "check list" impose certes de télécharger ces codes, mais il serait confortable pour l'admin d'y avoir accès, même quand l'élection est en cours.
3. Code d'authentification reçus par mail
Si on choisit l'option d'utiliser des codes d'authentification envoyés sur les mails des électeurs, le code apparaît dans le mail précédé d'un espace. Or dans de nombreux navigateurs/mail-managers (mais pas tous), les utilisateurs qui font un double-clic sur ce code vont aussi sélectionner l'espace qui le précède. Quand ils collent le code dans le champ affiché par le site, celui-ci considère que l'espace fait partie du code et renvoie donc une erreur "Echec de l'authentification". Cela peut engendrer, si les électeurs sont nombreux, une vague de mails signalant un problème, voire décourager certains (même pour si peu) de voter. Je pense qu'une simple modification du mail contenant le code enlevant cet espace, et/ou du code traitant le champ afin de "trim" son contenu pourrait résoudre ce petit inconvénient.
4. Possibilité de multi-admin
Enfin, il semble que la possibilité que plusieurs administrateurs gèrent la même élection ne soit pas proposée. Afin de contourner cette limitation, on peut toujours utiliser un compte partagé, mais ce n'est pas pratique pour tracer qui a modifié quoi, et pas très sécurisé non plus du fait du partage de compte (ce qui n'a dans ce cas rien à voir avec la sécurité offerte par Belenios bien entendu).
Dans l'ensemble nous sommes très satisfaits du service, merci encore pour sa mise à disposition, et pour votre attention.
Cordialement,
Pierre SCHWEITZER
- [belenios-discuss] Retour d'expérience et suggestions, Pierre Schweitzer, 12/01/2022
- Re: [belenios-discuss] Retour d'expérience et suggestions, Stéphane Glondu, 12/01/2022
