Accéder au contenu.
Menu Sympa
belenios-discuss - Re: [belenios-discuss] Self-hosted instance in a no-internet environment
Objet : Discussion list for Belenios
Archives de la liste
Chronologique Discussions
  • From: Stéphane Glondu <stephane.glondu AT inria.fr>
  • To: Alek Ohanian <alek.hayorti AT gmail.com>
  • Cc: belenios-discuss AT inria.fr
  • Subject: Re: [belenios-discuss] Self-hosted instance in a no-internet environment
  • Date: Tue, 15 Feb 2022 12:01:59 +0100
Hello,
Le 15/02/2022 à 09:59, Alek Ohanian a écrit :
> I was looking into Belenios and spent quite a bit of time getting it
> deployed, but then I realized that it doesn't appear like I can avoid
> the application's dependency on email. I thought removing email
> authentication and email settings from the config would let me use a
> standard username and password, which was true until the application
> asked me to add an email address to my user account.
> What I'm really interested in trying to do is to test the deployment of
> a voting system like Belenios in a completely enclosed environment
> that's completely cut off from the internet. The server and all of the
> clients would be connected via a local network and since none of them
> will be connected to the internet, none of them will have access to email.
> Is this something I could accomplish with Belenios?
How do you communicate with voters inside this restricted network?
Actually, the dependency on email is not that hard, just convenient. But
in theory, a private communication channel from election authorities to
voters is needed to bootstrap things.
Note that you don't need Internet access in order to have working
emails. Your email system can be restricted to an intranet.
Belenios sends emails with the "sendmail" command, which can be
overridden with the BELENIOS_SENDMAIL environment variable. Depending on
how you wish to communicate with voters, you can set this variable to a
suitable script.
On first login, the system does ask for an email address if it cannot
determine one by itself, but it is only used (at the moment) to pre-fill
the "Contact" field of elections, which is purely informative.
Note that if you choose the "secure" mode for credentials, they will not
be sent by the server itself (but someone will still have to send them
somehow). If, in addition, you choose an authentication scheme that does
not involve emails (such as CAS or OpenID Connect), the only emails that
Belenios will send are the confirmation emails (after a vote).
Cheers,
Stéphane
Belenios is free software. You can support us with a donation:
https://www.belenios.org/donations.html
Haut de le page
