Objet : Discussion list for Belenios
Archives de la liste
- From: Stéphane Glondu <stephane.glondu AT inria.fr>
- To: Roberto Blanco <roberto.blanco AT mpi-sp.org>
- Cc: belenios-discuss AT inria.fr
- Subject: Re: [belenios-discuss] Complex trustee structures with web server
- Date: Tue, 26 Apr 2022 07:34:51 +0200
- Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=stephane.glondu AT inria.fr; dmarc=fail (p=none dis=none) d=inria.fr
Le 25/04/2022 à 19:00, Roberto Blanco a écrit :
>> Anyway, implementing the feature natively in the web UI, without the
>> proxy-via-single-trustees hack of above, should be possible, but is not
>> on top of our priority list.
> Good to know! I had had a quick look at the code to get a feel for what
> the web server may be able to do. It did not seem then like it would be
> terribly complex, but coming up with a simple and above all usable
> design may not be trivial. If you think it would be useful to keep track
> of this closer to the repository, I could open an issue and write some
> initial thoughts there.
Yes, please do.
Best,
Stéphane
- [belenios-discuss] Complex trustee structures with web server, Roberto Blanco, 25/04/2022
- Re: [belenios-discuss] Complex trustee structures with web server, Stéphane Glondu, 25/04/2022
- Re: [belenios-discuss] Complex trustee structures with web server, Roberto Blanco, 25/04/2022
- Re: [belenios-discuss] Complex trustee structures with web server, Stéphane Glondu, 26/04/2022
