Objet : Discussion list for Belenios
Archives de la liste
- From: Stéphane Glondu <stephane.glondu AT inria.fr>
- To: "belenios-discuss AT inria.fr" <belenios-discuss AT inria.fr>
- Subject: [belenios-discuss] Belenios 2.1
- Date: Tue, 28 Feb 2023 09:19:41 +0100
- Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=stephane.glondu AT inria.fr; dmarc=fail (p=none dis=none) d=inria.fr
Hello,
I've just released Belenios 2.1.
The main visible differences with the previous version (2.0) are:
* When generating credentials, output private credentials in JSON (as
an object indexed by logins)
* Add support for Ed25519 (elliptic curve) group and use it by default
* Web server:
+ Add private key ownership check
+ Remove address input step in email authentication
+ Many changes in API, version bumped to 3
+ Pack JS files of the new booth
+ Pack CSS files
+ Add support for voters in JSON format
+ Interpret basic `<i>` and `<b>` markup (GitHub issue #66)
As usual, I've pushed a signed tag to the git repositories. Tarball and
signature are available at:
https://gitlab.inria.fr/belenios/belenios/-/releases
Cheers,
Stéphane
- [belenios-discuss] Belenios 2.1, Stéphane Glondu, 28/02/2023
