Accéder au contenu.
Menu Sympa
belenios-discuss - [belenios-discuss] Belenios 3.0
Objet : Discussion list for Belenios
Archives de la liste
Chronologique Discussions
  • From: Stéphane Glondu <stephane.glondu AT inria.fr>
  • To: "belenios-discuss AT inria.fr" <belenios-discuss AT inria.fr>
  • Subject: [belenios-discuss] Belenios 3.0
  • Date: Tue, 8 Oct 2024 11:05:30 +0200
  • Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=stephane.glondu AT inria.fr; dmarc=fail (p=none dis=none) d=inria.fr
Hello,
I've just released Belenios 3.0.
The main visible differences with the previous version (2.5.1) are:
* Specification:
+ Add support for "lists" questions
+ Add signature to `trustee_public_key` in threshold mode
+ Embed the specification in squashfs images
* Command-line tool:
+ Use unverified_ballots when computing encrypted tally, voters and
summary
+ Use encrypted tally from archive when computing decryption and
result
+ Use cohttp (instead of curl) for downloading election files
* Web server:
+ Randomize account ids
+ Big refactoring of storage backend
+ Change cookie handling for consent and language preference
+ Election home page:
- Revamp
- Show only the public key of threshold trustees
- Turn it into a SPA
- Incorporate ballot box browsing and advanced mode
+ Booth:
- Offer smart ballot tracker for download
- Change in authentication workflow
+ Avoid credential being saved in browser history
+ New admin UI:
- Many bugfixes and improvements to bring it in line with the
classical admin UI
- Add tests and continuous integration
+ Remove classical admin UI
+ Convert the trustee UIs (key generation, key check, partial
decryption and shuffle) to a single page application (SPA)
+ Convert the credential authority UIs (credential generation) to a
SPA
+ API:
- Bump version to 5
- Move "postpone" date to automatic dates and name it "publish"
date
- Many changes in endpoints to support SPAs
+ Tests and continuous integration:
- Add automatic tests of the new admin UI
- Add support for NH question and optional validation in scaling
- Add automatic test of monitoring
+ Configuration:
- Drop support for specifying groups by file
- Remove (unused) security log
- Add configurable vendor name
- Replace `<prefix>` and `<rewrite-prefix>` by a single
`<public-url>` tag
+ Documention:
- Nspawn: do not drop capabilities needed by logrotate
- Reverse-proxy: add a note about samesite=strict cookies
* Add unshare scripts to create squashfs images
There are also release notes for this version:
* Changes in configuration file:
+ `<uuid>`, `<spool>` and `<accounts>` elements are now children of
a new `<storage>` element (see example in
`demo/ocsigenserver.conf.in`)
+ in `<auth>` children, values of `db` and `allowlist` attributes
must be mapped to explicit files in the `<storage>` element
+ `<gdpr>` has been renamed to `<tos>`
+ Replace `<prefix>` and `<rewrite-prefix>` by a single
`<public-url>` tag
As usual, I've pushed a signed tag to the git repositories. Tarball and
signature are available at:
https://gitlab.inria.fr/belenios/belenios/-/releases
Cheers,
Stéphane
  • [belenios-discuss] Belenios 3.0, Stéphane Glondu, 08/10/2024
Haut de le page
