- To: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: [Cado-nfs-discuss] Duplicate las sieve processes
- Date: Mon, 19 Dec 2011 09:50:51 -0500
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hello, Because of having stopped and restarted cadofactor.pl at a point while it was passing out sieve jobs, I have a couple of machines which have duplicate copies of "las" with the same command line running concurrently on a single box. So, for example, we see something like this: > ps aux | grep lasIf I peek into the output files (which seem to be about 1/4 of the way done), they seem "OK" as far as I can tell(???). Namely, it seems things are being done in proper order without duplicate entries. For example: $ zcat /tmp/cado-data/myprob.rels.44000000-45000000.gz | grep SievHowever, processes that are duplicated do seem to be making significantly slower progress than the processes that aren't duplicated. So, my question is: Can I safely kill off one of the duplicate processes? Should I kill the newer or the older one? Or should I kill off both processes and restart somehow; and if so is there anything I need to do to ensure that I'll be able to make use of the progress made so far (about 20 hours worth on a couple different machines, and I'm paying for these cloud resources). Many thanks! -Zach |
- [Cado-nfs-discuss] Duplicate las sieve processes, Zachary Harris, 12/19/2011
- Re: [Cado-nfs-discuss] Duplicate las sieve processes, Emmanuel Thomé, 12/19/2011
- Re: [Cado-nfs-discuss] Duplicate las sieve processes, Zachary Harris, 12/19/2011
- <Possible follow-up(s)>
