- To: Shi Bai <shih.bai@gmail.com>
- Cc: "cado-nfs-discuss@lists.gforge.inria.fr" <cado-nfs-discuss@lists.gforge.inria.fr>
- Subject: Re: [Cado-nfs-discuss] Using GPU in Sieving Step
- Date: Thu, 16 Aug 2012 10:06:43 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hi,
Cofactorisation in nfs software has special-purpose code adapted to the composite sizes encountered.
Also, cofactorisation does early-abort every so often.
Gmp-ecm is neither designed for, nor adapted to the cofactoring situation. Different problems, different software.
To OP: no SLA implied with list membership. Thanks.
E.
Le 15 août 2012 15:33, "Shi Bai" <shih.bai@gmail.com> a écrit :
Hi Hamid, Zach,
On Sat, Aug 11, 2012 at 11:06 PM, Zachary Harris
<zacharyharris@hotmail.com> wrote:
> Hamid,
> Someone with greater expertise can correct me if I'm wrong, but I believe
> that, as a complete factorization algorithm itself, ECM is independent of
> NFS and therefore your answer is "No", it is in no way useful for the
> sieving part of NFS (i.e. ECM is not a sieve).
> As a rough heuristic, if I have a large number to factor, I'll hit it with
> ECM first to quickly pull out any small (~25 digit) factors, and then if the
> remaining factor is 60 digits or more I'll let NFS handle that.
It's more likely that Hamid mean the ECM for the cofactorization step?
> On 08/11/2012 01:40 AM, hamid reza arkian wrote:
> Hi,
> I have sent some questions 4 days ago, but I have not received any answer
> yet.
> Can anyone help me, please?
I know that some members of the CADO-NFS team are on holidays these
days so they may not see this.
> Thanks,
> Hamid
> On Tue, Aug 7, 2012 at 11:36 AM, hamid reza arkian <hamid.arkian@gmail.com>
> wrote:
>> Hi,
>> I tried GMP-ECM project (the branch that is currently under active
>> development for GPU devices) on a GPU cluster and got good results.
>> I want to replace ecm part of sieving step in CADO-NFS with GMP-ECM(that
>> support GPU), but I have the following questions:
>> - Basically, it's a good idea or not?
I personally think it's a good idea (though I admit I haven't wrote
codes for the sieving part.) But there could be some issues, such as
the stage 2 memory requirement. PS: I've CC-ed this email to Alex
Kruppa, who can answer this much better.
Kind regards,
Shi
>> - Is the GMP-ECM faster than ecm part of CADO-NFS? and if so, why the
>> developers don't do this replacement,yet?
_______________________________________________
Cado-nfs-discuss mailing list
Cado-nfs-discuss@lists.gforge.inria.fr
http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/cado-nfs-discuss
- [Cado-nfs-discuss] Using GPU in Sieving Step, hamid reza arkian, 08/07/2012
- Re: [Cado-nfs-discuss] Using GPU in Sieving Step, hamid reza arkian, 08/11/2012
- Re: [Cado-nfs-discuss] Using GPU in Sieving Step, Zachary Harris, 08/11/2012
- Re: [Cado-nfs-discuss] Using GPU in Sieving Step, Shi Bai, 08/15/2012
- Re: [Cado-nfs-discuss] Using GPU in Sieving Step, Emmanuel Thomé, 08/16/2012
- Re: [Cado-nfs-discuss] Using GPU in Sieving Step, Pierrick Gaudry, 08/20/2012
- Re: [Cado-nfs-discuss] Using GPU in Sieving Step, Zimmermann Paul, 08/20/2012
