- To: "cado-nfs-discuss" <cado-nfs-discuss@lists.gforge.inria.fr>
- Subject: [Cado-nfs-discuss] the theory behind the computation of alpha value
- Date: Mon, 20 Aug 2012 21:55:25 +0800
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hello all,
I read the c code about the computation of alpha value in auxiliary.c,
which can be used to measure the root properties of a polynomial. Though I
can use it directly, I don't know why to do that way. Would someone be kind
to explain the theory behind the algorithm or recommend some papers?
Thank you.
Best regards,
Sincerely Meng
- [Cado-nfs-discuss] the theory behind the computation of alpha value, mqseagle, 08/20/2012
- Re: [Cado-nfs-discuss] the theory behind the computation of alpha value, Zimmermann Paul, 08/20/2012
