- To: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: [Cado-nfs-discuss] some build problems
- Date: Sat, 24 Nov 2012 20:29:30 -0500 (EST)
- Importance: Normal
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hello,
I'm getting some build problems when attempting to compile git master
of CADO-NFS:
utils/relation.c now needs fgetc_unlocked, which neither OS X or
cygwin have
After working around that, in both OS X and cygwin I get
CMakeFiles/purge.dir/purge.c.o: In function `prempt_scan_relations_pass_two':
/home/jasonp/cado/filter/purge.c:1946: undefined reference to
`_pthread_tryjoin_np'
On 32-bit x86 I get
In file included from /home/jasonp/cado/linalg/bwc/mpfq/abase_vbase.c:6:0:
/home/jasonp/cado/linalg/bwc/mpfq/abase_p_4.h: In function
`abase_p_4_reduce':
/home/jasonp/cado/linalg/bwc/mpfq/abase_p_4.h:819:5: warning: right shift
count
>= width of type
In file included from /home/jasonp/cado/linalg/bwc/mpfq/abase_vbase.c:8:0:
/home/jasonp/cado/linalg/bwc/mpfq/abase_p_1.h: In function
`abase_p_1_reduce':
/home/jasonp/cado/linalg/bwc/mpfq/abase_p_1.h:819:5: warning: right shift
count
>= width of type
In file included from /home/jasonp/cado/linalg/bwc/mpfq/abase_p_1.c:4:0:
`abase_p_1_reduce':
count
>= width of type
/home/jasonp/cado/linalg/bwc/mpfq/abase_p_1.c: In function
`abase_p_1_vec_conv_u
r_ks':
/home/jasonp/cado/linalg/bwc/mpfq/abase_p_1.c:648:5: warning: comparison
between
signed and unsigned integer expressions
/home/jasonp/cado/linalg/bwc/mpfq/abase_p_1.c:656:5: warning: comparison
between
/home/jasonp/cado/linalg/bwc/mpfq/abase_p_1.c:671:5: warning: comparison
between
`abase_p_1_wrapper_ve
c_scal_mul':
/home/jasonp/cado/linalg/bwc/mpfq/fixmp_x86_32.h:14:3: error: can't find a
regis
ter in class `GENERAL_REGS' while reloading `asm'
/home/jasonp/cado/linalg/bwc/mpfq/fixmp_x86_32.h:14:3: error: `asm'
operand has
impossible constraints
linalg/bwc/CMakeFiles/bwc_mpfq.dir/build.make:169: recipe for target
`linalg/bwc
/CMakeFiles/bwc_mpfq.dir/mpfq/abase_p_1.c.o' failed
make[2]: *** [linalg/bwc/CMakeFiles/bwc_mpfq.dir/mpfq/abase_p_1.c.o] Error 1
and finally
In file included from /home/jasonp/cado/linalg/bwc/mpfq/abase_p_1_t.h:6:0,
from /home/jasonp/cado/linalg/bwc/mpfq/abase_p_1_t.c:4:
`abase_p_1_reduce':
count
>= width of type
/home/jasonp/cado/linalg/bwc/mpfq/abase_p_1_t.c: In function
`abase_p_1_p_1_dotp
rod':
regis
operand has
linalg/bwc/CMakeFiles/bwc_mpfq.dir/build.make:192: recipe for target
`linalg/bwc
/CMakeFiles/bwc_mpfq.dir/mpfq/abase_p_1_t.c.o' failed
make[2]: *** [linalg/bwc/CMakeFiles/bwc_mpfq.dir/mpfq/abase_p_1_t.c.o]
Error 1
Note that it isn't a big deal for me if support for 32-bit x86 is too
cumbersome in the current codebase.
jasonp
- [Cado-nfs-discuss] some build problems, Jason Papadopoulos, 11/25/2012
- Re: [Cado-nfs-discuss] some build problems, Emmanuel Thomé, 11/25/2012
