- To: paul leyland <paul.leyland@gmail.com>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] Documentation and/or parameter suggestions for SNFS
- Date: Fri, 25 Oct 2013 13:08:07 +0200 (CEST)
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
----- Original Message -----
> From: "Paul Leyland" <paul.leyland@gmail.com>
> To: cado-nfs-discuss@lists.gforge.inria.fr
> Sent: Thursday, 24 October, 2013 5:42:24 PM
> for SNFS
> (TL;DR --- having troubles setting up a SNFS factorization with
> cado-nfs 2.0 beta)
Yes, I agree that, if SNFS factorizations are a supported feature (which I
guess they are with the Python script), they need to be documented properly.
> On Thu, 2013-10-24 at 10:06 +0100, Paul Leyland wrote:
> Further to this, I'm trying to set up to factor 235*8^235+1 which has
> just started under "Msieve v. 1.52 (SVN 923M)". The msieve
> polynomial file, working very nicely, is
> n:
> 9344879323330582132476647523076036766251058644308032256575482675551196064229458278655388065516061224981191913520205352585413584634611067426349293720079701
> Y0: -166153499473114484112975882535043072
> Y1: 1
> c0: 1
> c1: 0
> c2: 0
> c3: 0
> c4: 0
> c5: 0
> c6: 1880
> skew: 0.284647271438178
> and I've saved that as msieve.poly on the system where cado-nfs is
> installed
This polynomial is actually already in CADO form; msieve, CADO, and afaik
ggnfs all use the same format. It's merely missing the common root m:
m: 166153499473114484112975882535043072
When I add this line, cadofactor.py accepts the polynomial and starts sieving.
We don't try to recover the common root from any linear polynomial or via
polynomial gcd, so the common root m must be specified explicitly.
> scripts/cadofactor/parameters.snfs for that.
> but that file isn't in the beta tarball ====> documentation bug at
> least.
Yes, it is. I'll try to make a few example parameter files for degree 4, 5,
6, and a few SNFS sizes each.
Sieving parameter choice for SNFS can vary wildly, depending on the degree
and coefficient size on the algebraic polynomial you get, but there should be
a handful of working examples provided as a starting point.
> The doc in scripts/cadofactor/README tells me to
> which I did. After unsuccessful attempts to convert to CADO-NFS
> format
> by hand I discovered /installed/bin/misc/convert_poly which is not
> obviously documented. After experimentation I used
> convert_poly -if msieve < msieve.poly > c8_235.poly
> with the result
> n: 0
> c0: 0
> Y0: 0
> m: 0
> which is not very helpful 8-(
This is probably a bug, I'll have to check.
> Tried again with the msieve c8_235.fb file as input to convert_poly.
> The contents this time are
> with result
> n:
> c6: 1880
> c5: 0
> c4: 0
> c3: 0
> c2: 0
> c1: 0
> c0: 1
> Y1: 1
This is the ggnfs/msieve/CADO format again, which should work, but missing
skewness, as you point out.
> Adding a line
> to c8_235.poly and restarting cadofactor.py produced
> Info:Client Launcher: Running clients: localhost4 (Host
> localhost, PID 4307), localhost3 (Host localhost, PID 4304),
> localhost2 (Host localhost, PID 4301), localhost (Host
> localhost, PID 4298)
> Info:Polynomial Selection: Starting
> Info:Polynomial Selection: No polynomial was previously found
> Warning:Polynomial Selection: Polynomial in
> file /home/pcl/cado_fact/c8_235.poly has no Murphy E value
> Info:Polynomial Selection: New best polynomial from
> file /home/pcl/cado_fact/c8_235.poly: Murphy E = 0
> Info:Polynomial Selection: Adding workunit
> c8_235_polyselect_0-100000 to database
> c8_235_polyselect_100000-200000 to database
> and now I'm stuck. What next?
> Note that I blew away the entire $(workdir) and any orphan
> polyselect2l
> process between each successive run of cadofactor.py
> Thanks for any assistance which may be forthcoming.
> Paul (this one)
The fact that it starts running polyselect jobs is a hint that admin < admax.
Can you check again that both are set to 0 to prevent it from starting a
polynomial search?
Alex
- Re: [Cado-nfs-discuss] Documentation and/or parameter suggestions for SNFS, Paul Leyland, 10/24/2013
- Re: [Cado-nfs-discuss] Documentation and/or parameter suggestions for SNFS, Alexander Kruppa, 10/25/2013
