- To: Sam Stoelinga <sammiestoel@gmail.com>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] Cado-nfs fails on duplicate removal
- Date: Sun, 2 Mar 2014 17:09:27 +0100 (CET)
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Yes, you can stop the factorization, change the number of clients or the
number of threads per client, and start it again - it should resume where it
left off. Having 20 threads per program is not very efficient, however, it's
better to have multiple processes with 2-4 threads each by running, say, 10
clients with 2 threads. Running fewer processes with more threads each saves
memory, however, so if you run out of memory, try 5 processes with 4 threads
each.
The sole exception is the linear algebra, which should get a larger number of
threads, for example with
tasks.threads=2
tasks.linalg.threads=16
This lets all programs use 2 threads, except 16 for the linear algebra.
Still, using 20 threads shouldn't cause any programs to fail, just run more
slowly than 10 programs with 2 threads each... I'll probably be able to see
the error message from the .log file, then I can check whether a large number
of threads causes something to break.
----- Original Message -----
> From: "Sam Stoelinga" <sammiestoel@gmail.com>
> To: "Alexander Kruppa" <alexander.kruppa@inria.fr>
> Cc: "paul leyland" <paul.leyland@gmail.com>,
> Sent: Sunday, 2 March, 2014 7:44:49 AM
> It seems it's still working but only using 1 thread. Can I update the
> params so that it restarts while using 20 threads? Or would that interfere?
> I tried to change the params to threads is 20 and clients is 1, but that
> would cause it to throw an exception saying Program failed.
> On Sun, Mar 2, 2014 at 2:34 PM, Sam Stoelinga <sammiestoel@gmail.com> wrote:
> > Hi All,
> > Just wanted to update you, that the change suggested by Paul and Alexander
> > is working as expected. It could now pass the duplicate checking! Thanks
> > for the fast help.
> > But another issue arrised it just got stuck at the following sentence:
> > Info:Linear Algebra: Starting and nothing is happening after that. See the
> > full log below.
> > Anybody ideas? I will try to just restart and see what happens.
> > This is the log:
> > Info:Lattice Sieving: Marking workunit c127_sieving_24370000-24373000 as
> > ok
> > Info:HTTP server: 127.0.0.1 Sending workunit
> > c127_sieving_24436000-24439000 to client localhost14
> > Info:Lattice Sieving: Adding workunit c127_sieving_24466000-24469000 to
> > database
> > Info:Lattice Sieving: Found 2838 relations in
> > '/tmp/cado.0ed8NN8FIA/c127.upload/c127.sieving.24376000-24379000.6w1kd6.gz',
> > total is now 15502175/15500000
> > Info:Lattice Sieving: Marking workunit c127_sieving_24376000-24379000 as
> > ok
> > c127_sieving_24439000-24442000 to client localhost18
> > Info:Lattice Sieving: Adding workunit c127_sieving_24469000-24472000 to
> > database
> > Info:Lattice Sieving: Reached target of 15500000 relations, now have
> > 15502175
> > Info:Filtering - Duplicate Removal, splitting pass: Starting
> > Info:Filtering - Duplicate Removal, splitting pass: Splitting 4793 new
> > files
> > c127_sieving_24442000-24445000 to client localhost8
> > c127_sieving_24445000-24448000 to client localhost12
> > c127_sieving_24448000-24451000 to client localhost11
> > Info:Filtering - Duplicate Removal, splitting pass: Relations per slice:
> > 0: 7748939, 1: 7753236
> > Info:Filtering - Duplicate Removal, removal pass: Starting
> > c127_sieving_24451000-24454000 to client localhost4
> > c127_sieving_24454000-24457000 to client localhost
> > c127_sieving_24457000-24460000 to client localhost15
> > c127_sieving_24460000-24463000 to client localhost3
> > c127_sieving_24463000-24466000 to client localhost10
> > Info:Filtering - Duplicate Removal, removal pass: 6473688 unique relations
> > remain on slice 0
> > c127_sieving_24466000-24469000 to client localhost13
> > c127_sieving_24469000-24472000 to client localhost19
> > Traceback (most recent call last):
> > File "/usr/libexec/cado-nfs/bin/wudb.py", line 1306, in run
> > try: result_tuple[0] = getattr(wuar, fn_name)(*args, **kargs)
> > File "/usr/libexec/cado-nfs/bin/wudb.py", line 954, in assign
> > cursor.begin(EXCLUSIVE)
> > File "/usr/libexec/cado-nfs/bin/wudb.py", line 223, in begin
> > self._exec("BEGIN EXCLUSIVE")
> > File "/usr/libexec/cado-nfs/bin/wudb.py", line 188, in _exec
> > self.execute(command)
> > sqlite3.OperationalError: database is locked
> > Info:Filtering - Duplicate Removal, removal pass: 6475897 unique relations
> > remain on slice 1
> > Info:Filtering - Duplicate Removal, removal pass: Of 15502175 newly added
> > relations 12949585 were unique (ratio 0.835340)
> > Info:Filtering - Duplicate Removal, removal pass: 12949585 unique
> > relations remain in total
> > Info:Filtering - Singleton removal: Starting
> > Info:Filtering - Singleton removal: Reading 12949585 unique and 63491 free
> > relations, total 13013076
> > Info:Filtering - Singleton removal: After purge, 3709934 relations with
> > 3709774 primes remain with weight 70418864 and excess 160
> > Info:Filtering - Singleton removal: Have enough relations
> > Info:Lattice Sieving: Cancelling remaining workunits
> > Info:Client Launcher: Stopped client localhost14 (Host localhost, PID
> > 2730)
> > Info:Client Launcher: Stopped client localhost17 (Host localhost, PID
> > 2751)
> > Info:Client Launcher: Stopped client localhost (Host localhost, PID 2640)
> > Info:Client Launcher: Stopped client localhost3 (Host localhost, PID 2653)
> > Info:Client Launcher: Stopped client localhost16 (Host localhost, PID
> > 2744)
> > Info:Client Launcher: Stopped client localhost10 (Host localhost, PID
> > 2703)
> > Info:Client Launcher: Stopped client localhost15 (Host localhost, PID
> > 2738)
> > Info:Client Launcher: Stopped client localhost20 (Host localhost, PID
> > 2772)
> > Info:Client Launcher: Stopped client localhost5 (Host localhost, PID 2667)
> > Info:Client Launcher: Stopped client localhost4 (Host localhost, PID 2660)
> > Info:Client Launcher: Stopped client localhost7 (Host localhost, PID 2682)
> > Info:Client Launcher: Stopped client localhost6 (Host localhost, PID 2675)
> > Info:Client Launcher: Stopped client localhost13 (Host localhost, PID
> > 2723)
> > Info:Client Launcher: Stopped client localhost12 (Host localhost, PID
> > 2717)
> > Info:Client Launcher: Stopped client localhost11 (Host localhost, PID
> > 2709)
> > Info:Client Launcher: Stopped client localhost2 (Host localhost, PID 2647)
> > Info:Client Launcher: Stopped client localhost9 (Host localhost, PID 2696)
> > Info:Client Launcher: Stopped client localhost8 (Host localhost, PID 2688)
> > Info:Client Launcher: Stopped client localhost19 (Host localhost, PID
> > 2766)
> > Info:Client Launcher: Stopped client localhost18 (Host localhost, PID
> > 2758)
> > Info:Filtering - Merging: Starting
> > On Sun, Mar 2, 2014 at 12:26 AM, Alexander Kruppa <
> >> > To: "paul leyland" <paul.leyland@gmail.com>
> >> > Sent: Saturday, 1 March, 2014 12:11:05 PM
> >> > Hi Paul,
> >> > I'm running 3.3.4 so is the bug also affecting me? I guess it is unless
> >> > they fixed the bug in python, unlikely.
> >> > Sam
> >> There are no updates on the bug: http://bugs.python.org/issue19003
> >> Thus I'm quite certain that the bug remains in Python 3.3.4. I this case,
> >> please change in wuclient2.py the list of affected versions from
> >> BUGGY_MIMEENCODER2 = (
> >> (3,2,4), (3,2,5),
> >> (3,3,2)
> >> to
> >> (3,2,4), (3,2,5),
> >> (3,3,2), (3,3,3), (3,3,4)
> >> Alex
> >> > On Sat, Mar 1, 2014 at 6:58 PM, Paul Leyland <paul.leyland@gmail.com>
> >> wrote:
> >> > > I had similar problems. Alex and Paul (the other one) helped me by
> >> > > pointing to a set of bugs in Python's MIME encoder.
> >> > > The workaround for me was to follow Alex' advice:
> >> > > > There is an entry on http://cado-nfs.gforge.inria.fr/ under Known
> >> Bugs;
> >> > > > do you happen to use Python 3.3.3 on the slaves? If yes, does
> >> > > > adding
> >> > > > (3,3,3) (without quotes) to the BUGGY_MIMEENCODER2 list in
> >> wuclient2.py
> >> > > > fix it?
> >> > > YMMV.
> >> > > Paul (this one)
> >> > > On Sat, 2014-03-01 at 18:48 +0800, Sam Stoelinga wrote:
> >> > > > Hi Pierrick,
> >> > > > Thanks for the fast reply!
> >> > > > 2.0 Version. Actually there were like 100+ files unrecoverable it
> >> > > > seems. I tried similar commands.
> >> > > > I used the Archlinux cado-nfs package from the aur.
> >> > > > I think the disk should be fine on that machine, although I can;t
> >> > > > promise that. I had the same problem on Amazon EC2 tried it 2
> >> > > > times.
> >> > > > This is the folder containing al related files:
> >> > > > http://pan.baidu.com/s/1hqgJDGg (Sorry for Chinese mirror)
> >> > > > On Sat, Mar 1, 2014 at 3:40 PM, Pierrick Gaudry
> >> > > > <pierrick.gaudry@loria.fr> wrote:
> >> > > > Hi,
> >> > > > Which version of cado-nfs did you use? The 2.0 or a recent
> >> git
> >> > > > version ?
> >> > > > At first sight, it seems that the error comes from a
> >> corrupted
> >> > > > relation
> >> > > > file. Maybe running
> >> > > > cd /tmp/cado.r1psyafiQA/c127.upload/
> >> > > > for i in c127.sieving.*; do gzip -t $i; done
> >> > > > will reveal a file that is not well formed.
> >> > > > If you put a tarball of your /tmp/cado.r1psyafiQA/
> >> > > > directory
> >> > > > somewhere for download, I can have a look.
> >> > > > You are not the first one who experienced problem with bad
> >> > > > relation
> >> > > > files. But it is hard to tell whether this is a bug in
> >> > > > Cado-nfs, or a
> >> > > > problem with disks...
> >> > > > Maybe we should add more checks that the files are
> >> > > > correctly
> >> > > > written to
> >> > > > disk and that the compression did well.
> >> > > > Regards,
> >> > > > Pierrick
> >> > > > On Sat, Mar 01, 2014 at 10:29:43AM +0800, Sam Stoelinga
> >> wrote:
> >> > > > > Hi,
> >> > > > > I get the following error while trying to factor:
> >> > > > > gzip: stdin: invalid compressed data--format violated
> >> > > > > filter_rels_producer_thread: load error (Bad file
> >> > > > descriptor) from
> >> > > > > It tries to execute this command it seems:
> >> > > > > ......... many more filesl_2ed.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.19687000-19690000.yr6eid.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.15931000-15934000.s9b_08.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.20965000-20968000.zo24c6.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.10804000-10807000.jszv9k.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.15352000-15355000.bpjgj5.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.23434000-23437000.u7_2tw.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.22465000-22468000.c21z8k.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.10699000-10702000.gq01be.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.21277000-21280000.o38532.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.15889000-15892000.as2trp.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.10231000-10234000.1sv89b.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.19729000-19732000.li0pv7.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.22060000-22063000.3_pxqo.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.15025000-15028000.sptcun.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.15217000-15220000.s5pszl.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.16585000-16588000.0q5cw7.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.22057000-22060000.efhup3.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.17077000-17080000.7jnsok.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.20683000-20686000.bdzp9e.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.18061000-18064000.4ybs_h.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.20785000-20788000.5ehwy1.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.18913000-18916000.xt3ama.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.15985000-15988000.ypj3cw.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.12790000-12793000.6lb_cc.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.10537000-10540000.3vbz_n.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.21955000-21958000.eyqdof.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.23818000-23821000.mht30j.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.16324000-16327000.4imyz7.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.17479000-17482000.685wuc.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.16504000-16507000.9sosap.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.23845000-23848000.ze28d6.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.21811000-21814000.zwhazw.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.15631000-15634000.x887_u.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.16942000-16945000.6htns3.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.12475000-12478000.aphbum.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.23674000-23677000.9wx6nt.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.21424000-21427000.pfh974.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.21874000-21877000.2imoc1.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.17326000-17329000.q4j94g.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.10894000-10897000.f0nc93.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.17944000-17947000.v9uz6n.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.20047000-20050000.kyuqxn.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.19468000-19471000.on99v0.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.16534000-16537000.g273_e.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.18736000-18739000.wtama2.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.17053000-17056000.eucwjm.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.22261000-22264000.m3mjz8.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.17353000-17356000.krizj8.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.13408000-13411000.paz5qu.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.17134000-17137000.3y1mfj.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.11803000-11806000.wlkoak.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.22570000-22573000.c43yts.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.14566000-14569000.gathsf.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.14575000-14578000.ff1a_4.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.19345000-19348000.gi8953.gz
> >> /tmp/cado.r1psyafiQA/c127.upload/c127.sieving.17836000-17839000.f6cc26.gz
> >> > > > > gzip -dc -
> >> > > > > Any help would be greatly appreciated! I can provide more
> >> > > > info as needed.
> >> > > > > Context: I'm using Cado-nfs to decrypt files which were
> >> > > > encrypted by some
> >> > > > > malware following this guide:
> >> > > http://blog.cassidiancybersecurity.com/post/2014/02/Bitcrypt-broken
> >> > > > > I'm doing this for a friend.
> >> > > > > Params used:
> >> > > > > slaves.basepath = /tmp/cado.r1psyafiQA/client/
> >> > > > > slaves.hostnames = localhost
> >> > > > > slaves.nrclients = 20
> >> > > > > slaves.niceness = 10
> >> > > > > slaves.scriptpath = /usr/libexec/cado-nfs/bin
> >> > > > > name = c127
> >> > > > > rlim = 5000000
> >> > > > > server.address = localhost
> >> > > > > N =
> >> 6197414403066148465767611830477972406781444626901692539671142017622145058977671120729249030073292775561014115285376040234795763
> >> > > > > alim = 10000000
> >> > > > > lpba = 27
> >> > > > > tasks.merge.coverNmax = 100
> >> > > > > tasks.execpath = /usr/libexec/cado-nfs/bin
> >> > > > > tasks.sieve.rels_wanted = 15500000
> >> > > > > tasks.sieve.mfba = 81
> >> > > > > tasks.sieve.mfbr = 54
> >> > > > > tasks.sieve.rlambda = 2.1
> >> > > > > tasks.sieve.qrange = 3000
> >> > > > > tasks.sieve.qmin = 10000000
> >> > > > > tasks.sieve.alambda = 2.8
> >> > > > > tasks.sieve.I = 12
> >> > > > > tasks.linalg.bwc.interval = 1000
> >> > > > > tasks.linalg.bwc.interleaving = 0
> >> > > > > tasks.linalg.bwc.mn = 64
> >> > > > > tasks.linalg.bwc.shuffled_product = 1
> >> > > > > tasks.linalg.characters.nchar = 50
> >> > > > > tasks.filter.merge.forbw = 3
> >> > > > > tasks.filter.purge.keep = 160
> >> > > > > tasks.filter.ratio = 1.1
> >> > > > > tasks.filter.maxlevel = 20
> >> > > > > tasks.threads = 1
> >> > > > > tasks.polyselect.incr = 60
> >> > > > > tasks.polyselect.maxnorm = 41.7
> >> > > > > tasks.polyselect.admax = 2000000
> >> > > > > tasks.polyselect.degree = 5
> >> > > > > tasks.polyselect.adrange = 20000
> >> > > > > tasks.polyselect.P = 50000
> >> > > > > tasks.polyselect.nq = 1000
> >> > > > > tasks.workdir = /tmp/cado.r1psyafiQA
> >> > > > > lpbr = 27
> >> > > > > _______________________________________________
> >> > > > > Cado-nfs-discuss mailing list
> >> > > > > Cado-nfs-discuss@lists.gforge.inria.fr
> >> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/cado-nfs-discuss
- [Cado-nfs-discuss] Cado-nfs fails on duplicate removal, Sam Stoelinga, 03/01/2014
- Re: [Cado-nfs-discuss] Cado-nfs fails on duplicate removal, Pierrick Gaudry, 03/01/2014
- Re: [Cado-nfs-discuss] Cado-nfs fails on duplicate removal, Sam Stoelinga, 03/01/2014
- Re: [Cado-nfs-discuss] Cado-nfs fails on duplicate removal, Paul Leyland, 03/01/2014
- Re: [Cado-nfs-discuss] Cado-nfs fails on duplicate removal, Alexander Kruppa, 03/01/2014
- Re: [Cado-nfs-discuss] Cado-nfs fails on duplicate removal, Sam Stoelinga, 03/02/2014
- Re: [Cado-nfs-discuss] Cado-nfs fails on duplicate removal, Alexander Kruppa, 03/02/2014
