- To: "cado-nfs-discuss@lists.gforge.inria.fr" <cado-nfs-discuss@lists.gforge.inria.fr>
- Subject: [Cado-nfs-discuss] CADO-NFS 2.1 release candidate
- Date: Tue, 20 May 2014 17:12:23 +0200 (CEST)
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear users,
a release candidate for version 2.1 of CADO-NFS is now available at
https://gforge.inria.fr/frs/?group_id=2065
It generally improves stability of the Python scripts over version 2.0, but
includes many other bug-fixes and improvements. It also adds unit tests,
please run "make check" after building and report any errors you may
encounter. Thank you!
>From the NEWS file:
Main changes between cado-nfs-2.0 and cado-nfs-2.1:
* Polynomial selection now runs in two separate phases, size optimization
and root optimization, with improved parameters
* Unit tests added, please run "make check" after building
* Various small speed-ups
* Various bug-fixes
* The wuclient2.py script no longer requires an external download tool
(wget or curl) to download securely via SSL under Python 2
* better support of DL in GF(p); still not fully automatic, nor
independent of third-party software. See README.dlp.
For assistance and bug reports, please post to this mailing list which does
not require registration, but is moderated.
Best regards and happy factoring,
the CADO team
- [Cado-nfs-discuss] CADO-NFS 2.1 release candidate, Alexander Kruppa, 05/20/2014
