- To: Raphaël Rigo <ml-cado@syscall.eu>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] Latest git fails make test
- Date: Tue, 5 Aug 2014 13:11:54 +0200 (CEST)
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
----- Original Message -----
> From: "Raphaël Rigo" <ml-cado@syscall.eu>
> To: "Emmanuel Thomé" <emmanuel.thome@gmail.com>
> Interestingly, I reran "make check" instead of "make test" :
> 100% tests passed, 0 tests failed out of 102
> Raphaël
This is by design. Unfortunately, CTest does not allow adding build
dependencies that are not themselves tests. Some tests require that some
binaries are built first which are not part of the "all" target. The usual
work-around is to introduce the "check" target which builds all required
binaries, and then runs the "test" target.
TLDR; don't do "make test", do "make check"
Alex
- [Cado-nfs-discuss] Latest git fails make test, Raphaël Rigo, 08/04/2014
- Re: [Cado-nfs-discuss] Latest git fails make test, Emmanuel Thomé, 08/04/2014
- Re: [Cado-nfs-discuss] Latest git fails make test, Raphaël Rigo, 08/04/2014
- Re: [Cado-nfs-discuss] Latest git fails make test, Alexander Kruppa, 08/05/2014
