- From: Pierpaolo Santucci <santucci.pierpaolo@gmail.com>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] Linear Algebra with MPI
- Date: Fri, 15 Aug 2014 19:12:33 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Using mpich2-1.5 in place of mpich-3.1.2, everything works fine.
Thanks for the support!On 14 August 2014 20:00, Pierpaolo Santucci <santucci.pierpaolo@gmail.com> wrote:
Thanks for the quick response.
In my local.sh there is:
MPI=/home/user/mpich-3.1.2/
Other steps of the GNFS (e.g. Polynomial Selection or Sieving) use MPI correctly.
Regards,
Pierpaolo SantucciOn 14 August 2014 19:47, Emmanuel Thomé <emmanuel.thome@gmail.com> wrote:
Most probably you haven't compiled cado-nfs for mpi use. There is an influential MPI variable which can be set from local.sh .
Please report how far you can go. I have little to no internet connection at all at the moment, but I'll try to help to the extent possible.
E.
Le 14 août 2014 19:20, "Pierpaolo Santucci" <santucci.pierpaolo@gmail.com> a écrit :_______________________________________________Hello everyone!
I'm interested in CADO-NFS 2.1 linear algebra. I want to execute the Block Wiedemann Algorithm on several hosts via MPI (mpich-3.1.2) but the command:
./bwc.pl :complete mpi=2 hosts=host1,host2 thr=4 mn=64 nullspace=left interval=100 matrix=/tmp/cado.XXXXBy837j/c90.merge.small.bin wdir=/tmp/tmp interleaving=0 shuffled_product=1
gives me the following error:
Inconsistency -- exactly 2 == 1 * 2 MPI jobs are needed -- got 1
./dispatch: exited with status 1
What's wrong?
Thanking you in advance.
Regards,
Pierpaolo Santucci
Cado-nfs-discuss mailing list
Cado-nfs-discuss@lists.gforge.inria.fr
http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/cado-nfs-discuss
- [Cado-nfs-discuss] Linear Algebra with MPI, Pierpaolo Santucci, 08/14/2014
- Re: [Cado-nfs-discuss] Linear Algebra with MPI, Emmanuel Thomé, 08/14/2014
- Re: [Cado-nfs-discuss] Linear Algebra with MPI, Pierpaolo Santucci, 08/14/2014
- Re: [Cado-nfs-discuss] Linear Algebra with MPI, Pierpaolo Santucci, 08/15/2014
