cado-nfs - Re: [Cado-nfs-discuss] "characters" fails with "all dependencies are zero"
  • To: "cado-nfs-discuss@lists.gforge.inria.fr" <cado-nfs-discuss@lists.gforge.inria.fr>
  • Subject: Re: [Cado-nfs-discuss] "characters" fails with "all dependencies are zero"
  • Date: Wed, 27 Aug 2014 12:04:38 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
FYI, I've just changed the default behaviour to be nullspace=left
unless told otherwise for linear algebra over GF(2) (factoring), while
the default is nullspace=right whenever p>2 (this is appropriate for
discrete log). This should remove the risk for failures such as the
one Raphaël encountered.
Best,
E.
On Mon, Aug 4, 2014 at 2:34 PM, Emmanuel Thomé <emmanuel.thome@gmail.com>
wrote:
> On Mon, Aug 4, 2014 at 2:06 PM, Raphaël Rigo <ml-cado@syscall.eu> wrote:
>> Unfortunately no I don't have the log :(
> Too bad.
>> But it appears I forgot to pass nullspace=left. Should I re-run the full
>> linalg step ?
> Yes unfortunately. It's really too bad. The default behaviour of
> nullspace=right inherits from the dark ages of this program, when it
> was used to do discrete logs. Now admittedly 99% of the use of this
> code base is with factoring, and we want left nullspace. Of course the
> python code in cado-nfs adds it, but bwc.pl itself does
> nullspace=right unless told otherwise.
> E.
