cado-nfs - Re: [Cado-nfs-discuss] (no subject)
  • To: John Waltos <jwaltos@hotmail.com>
  • Cc: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] (no subject)
  • Date: Sat, 13 Sep 2014 09:01:47 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hi John,
> From: John Waltos <jwaltos@hotmail.com>
> Date: Sat, 13 Sep 2014 04:21:05 +0000
> I will be setting up factorizations within CADO 2.1 to obtain polynomials.
> The values I intend to use are from 230 digits to a top end of 600 digits.
> I’ll be using a 6 core computer running Mageia 4.1 with 64 G RAM and about
> 800G of space.
> I would greatly appreciate any points on how to amend the parameter files
> as they cap out at 220 digits. Any pointers to a paper (s) directly
> addressing this would help also.
> Using GGNFS on Windows 7 last year, I was able to obtain a polynomial for a
> 298 digit factorization without any tweaks. It’s not pretty but is posted
> on the Mersenne forum.
> Thank you for any assistance.
> Very nice work!
what you are looking from is at the frontier of what we know. There was only
one factorization of 230 digits or more so far, namely RSA768.
For numbers in the 230-270 digit range, I would suggest using the following
parameters (adapted from params.c220):
tasks.polyselect.degree = 6
tasks.polyselect.P = 10000000 # maybe try 20M or 50M too
tasks.polyselect.admax = 1e8
tasks.polyselect.incr = 60
tasks.polyselect.nq = 46656 # this is 6^6
tasks.polyselect.nrkeep = 2000
You should adjust admax so that the total search takes at least 40 cpu years
(which was what we used for RSA768).
Note that even if you find a good polynomial, performing a full factorization
of a 230-digit number is a highly non-trivial task, and CADO-NFS 2.1 might not
be ready for that. Don't even dream about 600 digits.
Also note that recent results might give better polynomials [1].
Best regards,
Paul Zimmermann
[1] http://www.loria.fr/~zimmerma/papers/sopt-20140905.pdf
