cado-nfs - [Cado-nfs-discuss] CADO-NFS Issue - potential bug?
  • To: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: [Cado-nfs-discuss] CADO-NFS Issue - potential bug?
  • Date: Wed, 10 Dec 2014 10:13:05 +0000
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hello,
I'm using CADO-NFS to update Nadia Heninger's Factoring as a Service Project.
When using CADO in distributed mode to factor numbers, I have no issue for numbers below ~100 digits. However, when I try larger digits (RSA-120, for example), I get failed workunits, eventually leading to an aborted job.
My error message is listed below - does it lend any insight to something I may be doing wrong?
Thanks,
Sudarshan Muralidhar
Error:Polynomial Selection (size optimized): Program run on node015 failed with exit code 134
Error:Polynomial Selection (size optimized): Stderr output follows (stored in file /job10/c120.upload/c120_polyselect1_220000-224000.u2mm_t.stderr0):
b'# Warning: this code is experimental, and not thread-safe.
code BUG() : condition newsize == size failed in insert_hash at /home/cado-nfs/polyselect/auxiliary.c:3073 -- Abort
Aborted (core dumped)
Error:Polynomial Selection (size optimized): Exceeded maximum number of failed workunits, maxfailed=100
