- To: "Pierrick Gaudry" <pierrick.gaudry@loria.fr>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] major rewrite in the development version
- Date: Thu, 5 Mar 2015 20:56:32 +0800 (CST)
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Pierrick,
Thank you. checkout really works.
regards,
Meng
regards,
Meng
At 2015-03-05 20:48:04, "Pierrick Gaudry" <pierrick.gaudry@loria.fr> wrote: >Dear Meng, > >In order to choose a particular revision, you should use git checkout: > >First, clone as usual: > git clone https://gforge.inria.fr/git/cado-nfs/cado-nfs.git >then go to the particular revision > cd cado-nfs > git checkout ef16e0c > >Regards, >Pierrick > > >On Thu, Mar 05, 2015 at 08:38:39PM +0800, meng wrote: >> Dear Paul, >> use git https..., I get latest git version, which does not calculate Murhpy E value. So I use git clone ef16e0c. However, >> " fatal: repository 'ef16e0c' does not exist" was returned. I tried other git version and the same error was returned. >> How should I do ? >> Thank you. >> Best regards, >> Meng
- Re: [Cado-nfs-discuss] major rewrite in the development version, meng, 03/05/2015
- Re: [Cado-nfs-discuss] major rewrite in the development version, Pierrick Gaudry, 03/05/2015
- <Possible follow-up(s)>
- Re: [Cado-nfs-discuss] major rewrite in the development version, meng, 03/07/2015
- Re: [Cado-nfs-discuss] major rewrite in the development version, Pierrick Gaudry, 03/07/2015
- Re: [Cado-nfs-discuss] major rewrite in the development version, paul zimmermann, 03/09/2015
