cado-nfs - Re: [Cado-nfs-discuss] FileNotFoundError - can´t break my key
  • To: ВŁǺĉΚҒØҲלָ _____ <malath.7@hotmail.de>
  • Cc: "cado-nfs-discuss@lists.gforge.inria.fr" <cado-nfs-discuss@lists.gforge.inria.fr>
  • Subject: Re: [Cado-nfs-discuss] FileNotFoundError - can´t break my key
  • Date: Mon, 1 Jun 2015 16:29:49 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
You must compile the software first.
E.
On Mon, Jun 01, 2015 at 04:26:02PM +0200, ВŁǺĉΚҒØҲלָ _____ wrote:
> I tried to break this key:
> 55280852040745473243912002044914084681714903255599512351920243712316204129929151509737486668374516606706357874970901760899744279
> With this cado-nfs command:
> $ sh ./factor.sh
> -s 2 -t 2
> And get the following output:
> ./factor.sh: line 170: cd: ./build/MyUser: No such file or directory
> Info:root: Command line parameters:
> /var/cado-nfs-2.1.1/scripts/cadofactor/cadofactor.py /tmp/cado.H7
> xj4kmHki/param
> 'N=55280852040745473243912002044914084681714903255599512351920243712316204129929151509
> 737486668374516606706357874970901760899744279'
> 'tasks.execpath=/var/cado-nfs-2.1.1' 'tasks.threads=2'
> 'tasks.workdir=/tmp/cado.H7xj4kmHki' 'slaves.hostnames=localhost'
> 'slaves.nrclients=2' 'slaves.scrip
> tpath=/var/cado-nfs-2.1.1/scripts/cadofactor' 'server.address=localhost'
> 'slaves.basepath=/tmp/cado.H
> 7xj4kmHki/client/'
> Info:Server Launcher: Adding MyUser to whitelist to allow clients on
> localhost to connect
> Info:HTTP server: Using non-threaded HTTPS server
> Info:HTTP server: Using whitelist: localhost,MyUser
> Warning:HTTP server: Server is listening on the loopback device. Clients
> on other hosts will not be a
> ble to connect.
> Info:Complete Factorization: Factoring
> Info:HTTP server: serving at https://localhost:8001
> (127.0.0.1)
> Info:HTTP server: For debugging purposes, the URL above can be accessed
> if the server.only_registered
> =False parameter is added
> Info:HTTP server: You can start additional wuclient2.py scripts with
> parameters: --server=https://loc
> alhost:8001
> --certsha1=107b6d99b37d12de17f52764d7832c4ee362ce90
> Info:HTTP server: If you want to start additional clients, remember to
> add their hosts to server.whit
> elist
> Info:Client Launcher: Starting client id localhost on host localhost
> Warning:Command: Process with PID 7268 finished with return code 1
> Warning:Client Launcher: Starting client on host localhost failed.
> Warning:Client Launcher: Stderr: INFO:root:Starting client localhost
> INFO:root:Python version is 2.7.9
> INFO:root:Downloading certificate from localhost:8001
> INFO:root:Certificate SHA1 hash matches
> INFO:root:Writing certificate to file
> /tmp/cado.H7xj4kmHki/client/download/server.107b6d99.pem
> INFO:root:Running
> wget -V
> INFO:root:Running curl -V
> CRITICAL:root:HTTPS requested, but not implemented in Python 2 and can't
> find working wget or curl as
> fall-back. Aborting.
> Warning:Command: Process with PID 7240 finished with return code 1
> INFO:root:Using certificate stored in file
> SHA1 hash matches
> INFO:root:Running wget -V
> Info:Client Launcher: Running clients:
> Info:Polynomial Selection (size optimized): Starting
> Info:Polynomial Selection (size optimized): 0 polynomials in queue from
> previous run
> Traceback (most recent call last):
> File "/var/cado-nfs-2.1.1/scripts/cadofactor/cadofactor.py", line 72,
> in <module>
> factors = factorjob.run()
> File "/var/cado-nfs-2.1.1/scripts/cadofactor/cadotask.py", line 4720,
> in run
> last_status, last_task = self.run_next_task()
> File "/var/cado-nfs-2.1.1/scripts/cadofactor/cadotask.py", line 4788,
> in run_next_task
> return [task.run(), task.title]
> File "/var/cado-nfs-2.1.1/scripts/cadofactor/cadotask.py", line 1727,
> in run
> self.submit_one_wu()
> File "/var/cado-nfs-2.1.1/scripts/cadofactor/cadotask.py", line 1963,
> in submit_one_wu
> self.submit_command(p, "%d-%d" % (adstart, adend), commit=False)
> File "/var/cado-nfs-2.1.1/scripts/cadofactor/cadotask.py", line 1093,
> in submit_command
> wutext = command.make_wu(wuid)
> File "/var/cado-nfs-2.1.1/scripts/cadofactor/cadoprograms.py", line
> 597, in make_wu
> append_file(workunit, 'EXECFILE', str(filename))
> 591, in append_file
> wu.append('CHECKSUM %s' % sha1cache.get_sha1(filename))
> 192, in get_sha1
> stat = os.stat(realpath)
> FileNotFoundError: [Errno 2] No such file or directory:
> '/var/cado-nfs-2.1.1/polyselect2l'
> FAILED ; data left in /tmp/cado.H7xj4kmHki
> I use the Cygwin Terminal on a Windows 8.1 System
> I´ve already installed the Python 3 Package for Cygwin.
> I also tried it on a Ubuntu VM with the same result.
> Can anyone help me please
> _______________________________________________
> Cado-nfs-discuss mailing list
> Cado-nfs-discuss@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/cado-nfs-discuss
