cado-nfs - Re: [Cado-nfs-discuss] Uncompleted polyselect phase 1
  • To: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] Uncompleted polyselect phase 1
  • Date: Wed, 03 Jun 2015 20:47:45 +0000
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hi,
I have a similar question. Soon I will wish to stop phase 1 early and start phase 2 with the polys currently in the queue. What is the easiest way to do this?
Thanks,
Greg
On Wed, Jun 3, 2015, 11:32 AM Francois Morain <morain@lix.polytechnique.fr> wrote:
this happened to me in the case when the "main script" was busy before
starting the sieving part. So wait for the "main script" to start
the sieving jobs and start the slaves afterwards.
Hope this helps,
FMorain
Le Wed, Jun 03, 2015 at 07:38:58PM +0200, Christophe Clavier écrivait :
> Paul,
> Thank you for your insights.
> I succedeed in canceling the workunits.
> When I restart the server it does not seem to assign new workunits
> (neither for phase 1 nor phase 2):
> /Info:HTTP server: If you want to start additional clients, remember
> to add their hosts to server.whitelist//
> //Info:Polynomial Selection (size optimized): Starting//
> //Info:Polynomial Selection (size optimized): 700 polynomials in
> queue from previous run, worst lognorm 55.150000//
> When I start a client, it waits for a workunit to proceed with:
> /INFO:root:Running wget -V//
> //INFO:root:Downloading
> https://opn.msi.unilim.fr:8120/cgi-bin/getwu?clientid=node41.c0212823
> to download/WU.node41.c0212823 (cafile =
> download/server.a6da95a9.pem)//
> //ERROR:root:Download failed, URL error: HTTP Error 404: No work available//
> //ERROR:root:Waiting 10.0 seconds before retrying//
> //ERROR:root:Waiting 10.0 seconds before retrying (I have been
> waiting since 10.0 seconds)//
> waiting since 20.0 seconds)/
> Any idea?
> Christophe
> Le 03/06/2015 13:38, paul zimmermann a écrit :
> >        Christophe,
> >>Date: Wed, 03 Jun 2015 13:24:55 +0200
> >>From: Christophe Clavier <christophe.clavier@unilim.fr>
> >>Hello,
> >>During the first phase of the polynomial selection, 3 out of 100 range
> >>have been given to clients that unfortunately happened to be killed.
> >>Consequently, at the end of this phase the server is waiting for results
> >>from these clients and I would prefer not to wait for the timeout to elapse.
> >>Is there any means to restart the server so that it can give these
> >>ranges to some new clients, or alternatively so that it starts the
> >>second phase with the priority queue in its current state ?
> >>Regards
> >>Christophe
> >the following should do it:
> >$ wudb.py -dbfile cxxx.db -cancel <wuname>
> >You can get the names of the 3 remaining work-units as follows (see README
> >in scripts/cadofactor):
> >$ wudb.py -dbfile cxxx.db -dump -assigned
> >Please confirm it works,
> >Paul
> _______________________________________________
> Cado-nfs-discuss mailing list
> Cado-nfs-discuss@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/cado-nfs-discuss
--Fin du message d'origine--
