- To: Alex Liao <alexliao@seas.upenn.edu>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] Linear Algebra with MPI
- Date: Thu, 25 Jun 2015 10:35:22 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Alex,
Did that work eventually ?
E.
On Mon, Jun 22, 2015 at 09:40:51PM +0200, Emmanuel Thomé wrote:
> Hi,
> On Mon, Jun 22, 2015 at 12:44:36PM -0400, Alex Liao wrote:
> > Inconsistency -- exactly 4 == 2 * 2 MPI jobs are needed -- got 1
> This means that the binaries you are running are unaware of the existence
> of other MPI jobs. Most often, this is caused by the fact that you're
> trying to go MPI with a non-MPI build.
> > Any insight would be much appreciated. I'm using the version of CADO
> > pulled from the git repo and compiled using "MPI=/home/alexliao/.openmpi"
> > (OpenMPI 1.8.6)
> Most probably you haven't. Note that the build directory (by default
> $PWD/cado/`hostname`) is not by default dependent on the $MPI variable,
> nor are its contents. So if you do a plain "make" to start with, and
> later try an MPI build with the command
> "MPI=$HOME/packages/openmpi-1.8.6/ make" (no other syntax), then you'll
> be screwed because the build directory is without MPI, and object files
> won't get rebuilt.
> There are several ways to work around this quirk, choosing which way to
> go it is a matter of taste. You may want to force a fresh MPI build,
> as follows:
> rm -rf build/
> You may also have local.sh decide on the build tree location based on
> some influential env. variables. These are excerpts of what I have in my
> own local.sh:
> build_tree="${up_path}build/`hostname | cut -d. -f1 | sed -e
> 's/-[0-9]*$//'`"
> if [ "$MPI" ] ; then
> build_tree="${build_tree}.mpi"
> case "$MPI" in
> *mvapich2*) build_tree="${build_tree}.mvapich2";;
> *openmpi*) build_tree="${build_tree}.openmpi";;
> esac
> fi
> if [ "$DEBUG" ] ; then
> build_tree="${build_tree}.debug"
> # Dangerous pitfall -- mpicc has the nasty habit of forcing -O2 !
> export CFLAGS="-O0 -g"
> export CXXFLAGS="-O0 -g"
> fi
> If you can't fix your problem, please post the output of
> "MPI=/home/alexliao/.openmpi make cmake"
> Regards,
> E.
> _______________________________________________
> Cado-nfs-discuss mailing list
> Cado-nfs-discuss@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/cado-nfs-discuss
- Re: [Cado-nfs-discuss] Linear Algebra with MPI, Alex Liao, 06/22/2015
- Re: [Cado-nfs-discuss] Linear Algebra with MPI, Emmanuel Thomé, 06/22/2015
- Re: [Cado-nfs-discuss] Linear Algebra with MPI, Emmanuel Thomé, 06/25/2015
- Re: [Cado-nfs-discuss] Linear Algebra with MPI, Alex Liao, 06/25/2015
