- To: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: [Cado-nfs-discuss] A curious make error
- Date: Mon, 31 Aug 2015 14:46:45 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=paul.leyland@gmail.com; spf=Pass smtp.mailfrom=paul.leyland@gmail.com; spf=None smtp.helo=postmaster@mail-wi0-f176.google.com
- Ironport-phdr: 9a23:zmvlthevjcfv1pIWpInNX21qlGMj4u6mDksu8pMizoh2WeGdxc+6YB7h7PlgxGXEQZ/co6odzbGG6Oa/ACdesd6oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDpvcKKKFsYzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IZ4yhIP99FeAQTGl+cjN92Mq+vhDPSk6J6GBZXmQNmQdTGCDB7QrmRdH+vCzguec72S+APMSwQ6pnYzm667ZXT0rwgToDcTo04WXejMBYg6dSoRbnrBt6kKDOZ4TADPNjeuv5cMIeTGxNFpJJXjFFRIexfo8GCeYpMuNRro27rFwL+0jtTTKwDf/in2cbzkT92rc3hrl5HA==
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
See these screen snips;
pcl@maat ~/nums/cado-nfs $ make -n
./scripts/call_cmake.sh all
CMake found, but not with version 2.8 or newer
I am about to download and compile a compatible version of Cmake.
Do you want to continue ? (y/n)
n
Please install a compatible version of Cmake.
Makefile:5: recipe for target 'all' failed
make: *** [all] Error 1
pcl@maat ~/nums/cado-nfs $ emerge --search cmake
[ Results for search key : cmake ]
Searching...
* dev-util/cmake
Latest version available: 3.2.2
Latest version installed: 3.2.2
Size of files: 6,288 KiB
Homepage: http://www.cmake.org/
Description: Cross platform Make
License: CMake
So this Gentoo has CMake 3.2.2 installed but cado-nfs thinks that it's
older than 2.8!
Paul
- [Cado-nfs-discuss] A curious make error, Paul Leyland, 08/31/2015
- Re: [Cado-nfs-discuss] A curious make error, Emmanuel Thomé, 08/31/2015
- Re: [Cado-nfs-discuss] A curious make error, paul zimmermann, 08/31/2015
- Re: [Cado-nfs-discuss] A curious make error, Paul Leyland, 08/31/2015
