cado-nfs - Re: [Cado-nfs-discuss] Cado-NFS errror
  • To: Marcin Barański <baranek2223@wp.pl>
  • Cc: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] Cado-NFS errror
  • Date: Fri, 23 Oct 2015 14:53:52 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Marcin,
does it work if you replace -h 10.1.0.65 by say -h www.fbi.gov where
www.fbi.gov is the corresponding human-readable machine name?
Another thing you can try is adding server.whitelist=127.0.0.1 at the end of
the factor.sh command line.
If it does not work, please can you send us the full output you get?
The "Info:HTTP server" lines are missing.
Paul Zimmermann
> Date: Fri, 23 Oct 2015 08:08:04 +0200
> From: Marcin Barański <baranek2223@wp.pl>
> Hello,
> I think i had done the ssh-agent and ssh-add section, but when i try to run
> ./factor.sh
> 353493749731236273014678071260920590602836471854359705356610427214806564110716801866803409
> -t 1 -s 2 -h 10.1.0.65
> 10.1.0.65 - is client ip address
> i got an error below:
> Info:Client Launcher: Starting client id 10.1.0.65 on host 10.1.0.65
> Warning:Command: Process with PID 14850 finished with return code 1
> Warning:Client Launcher: Starting client on host 10.1.0.65 failed.
> Warning:Client Launcher: Stderr: INFO:root:Starting client 10.1.0.65
> INFO:root:Python version is 2.7.3
> INFO:root:Downloading certificate from ubuntu:8001
> Traceback (most recent call last):
> File "/usr/local/cado-nfs-2.1.1/scripts/cadofactor/wuclient2.py", line
> 1563, in <module>
> if not get_missing_certificate(certfilename, netloc,
> SETTINGS["CERTSHA1"]):
> 1347, in get_missing_certificate
> retrytime=retrytime)
> 1315, in get_ssl_certificate
> ca_certs=None)
> File "/usr/lib/python2.7/ssl.py", line 442, in get_server_certificate
> s.connect(addr)
> File "/usr/lib/python2.7/ssl.py", line 331, in connect
> self._real_connect(addr, False)
> File "/usr/lib/python2.7/ssl.py", line 324, in _real_connect
> raise e
> socket.gaierror: [Errno -5] No address associated with hostname
> I try to change the nosha1check option in wuclient2.py to default=true on
> server and on client pc's but i got same error.Any advices?
> M.Baranski
> _______________________________________________
> Cado-nfs-discuss mailing list
> Cado-nfs-discuss@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/mailman/listinfo/cado-nfs-discuss
