cado-nfs - Re: [Cado-nfs-discuss] cado-nfs cmake build using icpc
  • To: ƦOB COASTN <robertpancoast77@gmail.com>
  • Cc: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] cado-nfs cmake build using icpc
  • Date: Thu, 29 Oct 2015 21:38:22 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
On Thu, Oct 29, 2015 at 04:14:16PM -0400, ƦOB COASTN wrote:
> Hello,
> Attached to this message are the results from RSA120 factorization and the
> intel build log for the host binaries.
> Please pardon the lengthy output.
> The baseline RSA120 results for the k1om benchmark are outlined below:
> dual 6core Intel(R) Xeon(R) CPU E52603 && (8) Xeon PHI 5110P
> RSA120: 1.65 hours = >1 day = 4.53089e+06/5940.38
> If we compare to the baseline for RSA120 on the cado homepage:
> dual 8core Intel(R) Xeon(R) CPU E52650
> RSA120: 43.9 hours = ~2 days = ~158040
> Comparison:
> It is unfair to directly compare 10 processors to 2, but here are the
> results anyway.
> 158040 / 5941 = 26.6x Speed-up!
> We could argue that they both exist as one computation node.
right, you may have a point ;-)
> The host binaries for ICC build fails with the message below:
> Scanning dependencies of target las
> [ 37%] Building CXX object sieve/CMakeFiles/las.dir/las.cpp.o
> /home/cado-nfs/sieve/las.cpp(1784): error: argument of type "unsigned char
> *" is incompatible with parameter of type "const char *"
> _mm_prefetch(((unsigned char *) it)+256, _MM_HINT_NTA);
That should not be hard to fix.
E.
