- From: Christophe Clavier <christophe.clavier@unilim.fr>
- To: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: [Cado-nfs-discuss] Relation file computed but not sent back to the server
- Date: Wed, 2 Dec 2015 19:55:05 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=christophe.clavier@unilim.fr; spf=Pass smtp.mailfrom=christophe.clavier@unilim.fr; spf=None smtp.helo=postmaster@smtp.unilim.fr
- Ironport-phdr: 9a23:JZ/eEBfZZHqJH+h1UEBbAiNNlGMj4u6mDksu8pMizoh2WeGdxc68YR7h7PlgxGXEQZ/co6odzbGG7ea4ASQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTpkbjqs7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JtLWKn9OqI2VvlUDS8tLnsuzMnqrgXYCwSB4WETXyMXlABJCk7L9kLURJD05wD6rOtmxC6CPcC+ZrQ9RzWv9e8/Qx/yiTwbMCY5/SfcjsVuja9BiA+nphh+xsjaetfGZ7JFYqrBcIZCFiJ6VcFLWnkZDw==
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hello,
Let me describe what I would like to do in a current factorization:
When one of my clients finished its assigned workunit the connection with the server was off.
In this situation the client waits by polling until the connection is restored so that it can then send the relations file back to the server.
In my case the client has been killed (power off of the computer) during the pooling phase.
When I start a new client a new workunit is assigned but the already computed relation file is not retrieved by the server.
Is there any means to provide this relation file to the server? Maybe a manual hack with the workunit database?
Thank you for your insights.
Christophe
- [Cado-nfs-discuss] Relation file computed but not sent back to the server, Christophe Clavier, 12/02/2015
- Re: [Cado-nfs-discuss] Relation file computed but not sent back to the server, Emmanuel Thomé, 12/02/2015
