cado-nfs - [Cado-nfs-discuss] cado-nfs 2.2.0 release
  • To: Cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: [Cado-nfs-discuss] cado-nfs 2.2.0 release
  • Date: Fri, 11 Dec 2015 14:06:08 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear users of cado-nfs,
we are happy to announce the release of cado-nfs 2.2.0, available from
http://cado-nfs.gforge.inria.fr/.
Timings to factor RSA-120, RSA-130, RSA-140 and RSA-155 (to be published soon)
will show cado-nfs 2.2.0 is much faster than previous releases.
The CADO-NFS Development Team
Main changes between cado-nfs-2.1.1 and cado-nfs-2.2.0:
* The toplevel scripts (factor.sh, cadofactor.py, wuclient2.py) have
changed. Now there are only two main scripts to be used by most users:
- cado-nfs.py
This combines the roles of the previous factor.sh and cadofactor.py.
The most basic use is ./cado-nfs.py <N>, and it will factor N on the
local host. It can also become a server in a multi-host
computation. See README for more details.
- cado-nfs-client.py
This is mostly a renaming of wuclient2.py. This starts a client that
can contribute to a running computation, possibly on another
machine.
By default, factorizations running on the localhost will use all
available cores.
* Main algorithmic improvements:
- polynomial selection: algorithm of Bai, Bouvier, Kruppa, Zimmermann
(Better polynomials for GNFS, 2015) has been implemented.
- relation collection: multi-level buckets for better handling of
medium-sized primes; cofactorization strategies à la Kleinjung. Both
features are experimental, and not activated by default.
- linear algebra: support for non-binary base field (for dlp),
including the removal of the overhead due to SMs.
* Main speedups:
- the creation of the factor base is now multithread.
- linear algebra speedup taking into account machine topology thanks to
HWLOC (http://www.open-mpi.org/projects/hwloc/).
- the square root step is now multithread.
- default parameters files were optimized for sieving with OPAL/nomad.
* DLP support: now fully functional over prime fields, including the
descent step. Still requires Magma for a small number-theoretic
computation at the beginning (dependency will be removed sooner or later).
See README.dlp for further details.
* In local.sh, the customization of the build_tree using the $up_path
variable used to be phrased as: build_tree="${up_path}some/sub/path".
Now it should be build_tree="${up_path}/some/sub/path", as $up_path no
longer embodies a trailing /
* The polynomial file now supports another format. For giving a
polynomial, a line like
poly0=17,42,34,55
can be written, to set the polynomial 17+42*x+34*x^2+55*x^3 on side 0.
The old format with X, c, Y,... is still supported, with c and X for
side 1 and Y for side 0.
* References to rational or algebraic sides have been reduced (at least
internally). This means that several parameters have now aliases
corresponding to sizes. For instance, the parameter -lpb1 for las is an
alias of -lpba. The common convention is that the rational side (if
any) is on side 0, but everything will work if a polynomial file is imported
with the rational side on side 1.
* Various changes in the parameter list for the linear algebra task,
in particular, the linalg.bwc.mn=... parameter is replaced by 2
separate parameters for m and n. Also the rhs=... parameter allows
non-homogeneous system solving (useful for handling SMs with no
overhead in DLP mode).
* An estimated time of arrival (ETA) is now printed during the polynomial
selection and sieving steps. It corresponds to the estimate finish time
of each of those steps (not the full factorization).
  • [Cado-nfs-discuss] cado-nfs 2.2.0 release, paul zimmermann, 12/11/2015
