- To: Cyril Bouvier <Cyril.Bouvier@loria.fr>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] c192 : crash during merge (insufficient memory)
- Date: Mon, 04 Jan 2016 13:20:35 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Christophe,
> To reduce the memory usage in merge you can reduce the value of the
> command line argument -maxlevel (the maximum weight of columns
> considered for merge).
> Also the memory usage increases during merge (because the total weight of
> the matrix increases), but you can set the command line argument
> -target_density to 150 or 100 to produce a bigger matrix with a smaller
> total weight.
if this does not work, another solution is to do more sieving, to reduce the
matrix size at the end of purge.
Paul
- [Cado-nfs-discuss] c192 : crash during merge (insufficient memory), Christophe Clavier, 01/03/2016
- Re: [Cado-nfs-discuss] c192 : crash during merge (insufficient memory), Cyril Bouvier, 01/04/2016
- Re: [Cado-nfs-discuss] c192 : crash during merge (insufficient memory), paul zimmermann, 01/04/2016
