- To: ƦOB COASTN <robertpancoast77@gmail.com>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] cado-nfs-2.2.0 RSA-120 MIC Benchmark
- Date: Thu, 07 Jan 2016 09:01:12 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Rob,
> Using bridged networking and 8 MIC co-processors, hybrid Xeon and Xeon
> Phi execution is feasible. Ten factor trials of RSA-120 finished in
> under 2 hours.
> (1.6337+1.6400+1.6357+1.7245+1.6255+1.7062+1.6105+1.6214+1.6021+1.6321)/10=1.64317
> hrs
I've just added timings on http://cado-nfs.gforge.inria.fr/ with 2.2.0:
on a dual 8-core Intel(R) Xeon(R) CPU E5-2650 at 2.00GHz, factoring
RSA-120 with CADO-NFS 2.2.0 takes about 2.2 hours of wall clock time
(32.2 hours of cpu time). You used about 1200 hours cpu.
> 1.) Will MPI enable utilization of the 1920 MIC cores for linalg?
I let Emmanuel answer to that.
> 2.) Will MPI enable utilization of the 1920 MIC cores for sqrt?
there is no need. The square root step takes negligible time.
> 3.) Will MIC offloading enable utilization of the 1920 MIC cores for linalg?
> 4.) Will MIC offloading enable utilization of the 1920 MIC cores for sqrt?
> 5.) Considering future-proof development, should efforts focus on MIC
> offloading or MPI?
I'm not sure this make sense, given the relative slowness of the MIC cores
(1200 cpu hours for RSA-120 instead of 32 cpu hours).
Paul
- [Cado-nfs-discuss] cado-nfs-2.2.0 RSA-120 MIC Benchmark, ƦOB COASTN, 01/07/2016
- Re: [Cado-nfs-discuss] cado-nfs-2.2.0 RSA-120 MIC Benchmark, paul zimmermann, 01/07/2016
- Re: [Cado-nfs-discuss] cado-nfs-2.2.0 RSA-120 MIC Benchmark, Emmanuel Thomé, 01/07/2016
- Re: [Cado-nfs-discuss] cado-nfs-2.2.0 RSA-120 MIC Benchmark, ƦOB COASTN, 01/07/2016
