- From: Aurore Guillevic <guillevic@lix.polytechnique.fr>
- To: Reuben Smith <rbnsmith00@gmail.com>, cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] DLP generator
- Date: Tue, 15 Mar 2016 19:16:27 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=guillevic@lix.polytechnique.fr; spf=None smtp.mailfrom=guillevic@lix.polytechnique.fr; spf=None smtp.helo=postmaster@mx-a.polytechnique.fr
- Ironport-phdr: 9a23:6CyANRbmGJIr66OgJa+J3KL/LSx+4OfEezUN459isYplN5qZpM+6bnLW6fgltlLVR4KTs6sC0LqG9fi4EjxQqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh7D0o8WYM1UArQH+SI0xBS3+lR/WuMgSjNkqAYcK4TyNnEF1ff9Lz3hjP1OZkkW0zM6x+Jl+73YY4Kp5pIZoGJ/3dKUgTLFeEC9ucyVsvJWq5lH/Sl6162YWX2NeqR9JHwiNuAvwWIz0szf67rJV1yyTPMmwRrcxD3Dq5K5nT1ruhjxCOz8i+3zMkeR0jblHu1SuqRtlzIOSYYePNfM4cLmOU8kdQD9oQ9xWTSEJLZ69a48CEesKdbJXsoj5o1YQrBCWAQi8Qvvozi5Ui3T226wjzulnHxuQj19oJM4HrHmB9Ia9D6wVS+3gifCQlTg=
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Reuben Smith, Yes the logarithms are given in the implicit base used by cado-nfs. The logarithms are called "virtual" in cado-nfs. The first simple way to obtain the logarithm of your target in your favorite basis G, you need to compute the discrete logarithm of your generator G in the cado-nfs basis, so that you can compute log_{basis G}(target) = log_{cado-nfs basis}(target)/log_{cado-nfs basis}(G). Aurore. -- Aurore Guillevic Post-doctoral scholar Computer Science Department University of Calgary/PIMS/CNRS AB, Canada http://www.lix.polytechnique.fr/~guillevic On 15/03/2016 18:52, Reuben Smith
wrote:
Hello everyone,
What is the reason?I want to use CADO-NFS for solving a small dlp. In README.dlp it is specified that "the logarithms are given in an arbitrary base.". Is there some way to get the generator used? Reuben _______________________________________________ Cado-nfs-discuss mailing list Cado-nfs-discuss@lists.gforge.inria.fr http://lists.gforge.inria.fr/mailman/listinfo/cado-nfs-discuss |
- [Cado-nfs-discuss] DLP generator, Reuben Smith, 03/15/2016
- Re: [Cado-nfs-discuss] DLP generator, Aurore Guillevic, 03/15/2016
- Re: [Cado-nfs-discuss] DLP generator, Pierrick Gaudry, 03/16/2016
