- To: "paul zimmermann" <Paul.Zimmermann@inria.fr>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] how to configure parameters
- Date: Fri, 1 Apr 2016 19:56:18 +0800 (CST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=qsmeng@126.com; spf=Pass smtp.mailfrom=qsmeng@126.com; spf=None smtp.helo=postmaster@m15-34.126.com
- Ironport-phdr: 9a23:O34Cth/4u8W41v9uRHKM819IXTAuvvDOBiVQ1KB91OgcTK2v8tzYMVDF4r011RmSDdWdsKgP17KempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXsq3G/pQQfBg/4fVIsYL+lSsiJ1Y/rj6ibwN76XUZhvHKFe7R8LRG7/036l/I9ps9cEJs30QbDuXBSeu5blitCLFOXmAvgtI/rpMYwuwwZgf8q9tZBXKPmZOx4COUAVHV1e1wysYfzvATHBRmO434RSGAflBwCS1z95Qz+GKXwty73rO903i+yPMvsTLlyVy70vIlxTxq9jSoBOHZxpHjMj8F2g4oC+kznrBt6ld2HKLqJPeZzK/uONegRQnBMC4MID3RM
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Paul,
At 2016-03-31 23:12:11, "paul zimmermann" <Paul.Zimmermann@inria.fr> wrote:
> Dear Meng,
>> Date: Thu, 31 Mar 2016 22:13:53 +0800 (CST)
>> From: meng <qsmeng@126.com>
>> Dear Paul,
>> In cado-nfs2.2,you used method from your paper "better polynomial", where for different skewness, there exist many plolynomials. I obtain new polynomials by one polynomial subtracting another one and then select the one with smaller leading coefficient. usually these new polynomials will have smaller lognorm.
>> I just use version 2.2 and the command is cado.py N workdire
>> Best regards,
>> Meng
>thus I conclude the better polynomial you got for RSA-120 was obtained with a
>modified version of cado-nfs. Just curious, what is this polynomial?
> >Paul
the polynomial goes like this:
n: 227010481295437363334259960947493668895875336466084780038173258247009162675779735389791151574049166747880487470296548479
skew: 34768.0
c0: 8300254538725833888531445545
c1: 665466551407346306968179
c2: 9320605370626500511
c3: 27435101433965
c4: -28964342892
c5: 19260
Y0: 2006365639456767948836
Y1: 2447097403723699729
# MurphyE (Bf=3.41e+06,Bg=1.57e+06,area=2.86e+13) = 9.43e-10
# lognorm 37.82
In fact, I am also curious about the form it has before the root optimization. it is the 557 polynomial after size optimization, but is the best after root optimization.
Regards,
Meng
> >Paul
skew: 34768.0
c3: 27435101433965
c4: -28964342892
c5: 19260
# lognorm 37.82
Regards,
Meng
- Re: [Cado-nfs-discuss] how to configure parameters, meng, 04/01/2016
- Message not available
- Re: [Cado-nfs-discuss] how to configure parameters, paul zimmermann, 04/08/2016
