- To: "cado-nfs-discuss" <cado-nfs-discuss@lists.gforge.inria.fr>
- Subject: [Cado-nfs-discuss] Gf2x error
- Date: Fri, 15 Apr 2016 07:35:01 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=baranek2223@wp.pl; spf=Pass smtp.mailfrom=baranek2223@wp.pl; spf=None smtp.helo=postmaster@mx4.wp.pl
- Ironport-phdr: 9a23:8wCa5xXdg5EOlxSEya1PP8mxeYvV8LGtZVwlr6E/grcLSJyIuqrYZhOPt8tkgFKBZ4jH8fUM07OQ6PCwHzFfqsfe+Fk5M7VyFDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpq82VPloD1WX1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu2pN5g/GPZTBTghdmY7/4jntALIUBCUrDNIWWwalV9ODROA4BDhVYrqqQP+t/Fhw2+VM8rsQr1yWDK47q4tRgW+2wkdMDts1WjNgc12u4hSuhsYvB9+i9reaZucMvd9JPmHJvsFXSxZWpACBGR6HoqgYt5XXKI6NuFCotylqg==
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
- Organization: Poznaj Poczte WP http://poczta.wp.pl/info-start.html
Hello,
I have another problem.
When i try to run make in command line in cado 2.2.0 folder I got an error
showed below:
make
[ 0%] Configuring gf2x
Configuring gf2x with options --disable-shared --disable-dependency-tracking
--enable-fft-interface CC=/usr/bin/cc CXX=/usr/bin/c++ CFLAGS=-std=c99 -g -W
-Wall -O2 -I/home/idm/mbaranski/Cado/Biblioteki/Gmp/gmp-6.1.0
-I/home/idm/mbaranski/Cado/Cado/cado-nfs-2.2.0 CXXFLAGS=-std=c++11 -g -W
-Wall -Wno-literal-suffix -O2
LDFLAGS=/home/idm/mbaranski/libs/ -Wl,-rpath,/home/idm/mbaranski/libs/lib
-L/home/idm/mbaranski/libs/lib
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking target system type... x86_64-unknown-linux-gnu
checking for gcc... /usr/bin/cc
checking whether the C compiler works... no
configure: error: in
`/home/idm/mbaranski/Cado/Cado/cado-nfs-2.2.0/build/prl.hpc.cslab.pl/gf2x':
configure: error: C compiler cannot create executables
See `config.log' for more details
make[2]: *** [gf2x/Makefile] Error 77
make[1]: *** [CMakeFiles/gf2x-build.dir/all] Error 2
make: *** [all] Error 2
My system is 64 bit CentOS.
Output of gcc -version:
gcc --version
gcc (GCC) 4.8.3 20140911 (Red Hat 4.8.3-9)
Copyright (C) 2013 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Pozdrawiam
Marcin Barański
- [Cado-nfs-discuss] Gf2x error, Marcin Barański, 04/15/2016
- <Possible follow-up(s)>
- Re: [Cado-nfs-discuss] Gf2x error, paul zimmermann, 04/18/2016
- [Cado-nfs-discuss] Gf2x error, Marcin Barański, 04/18/2016
- Re: [Cado-nfs-discuss] Gf2x error, Emmanuel Thomé, 04/18/2016
