- To: Timothy Geiser <slimshady007@gmail.com>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] 2.2.0 build fails on MacOS X 10.9.5
- Date: Mon, 05 Sep 2016 17:12:36 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Timothy,
it seems the compiler you are using (AppleClang 6.0.0.6000057) is more strict
than the one we used to test CADO-NFS 2.2.0. However the "errors" you report
are just warnings for unused functions, which are turned into error because
of -Werror. To disable -Werror, simply remove the following lines in cado.h:
/* This has the same effect as enforcing -Werror on the command line, so
* as to trigger as many warnings as we can, and force ourselves to get
* them fixed.
* (useful to enable temporarily before releases, at least)
#ifdef __GNUC__
#pragma GCC diagnostic error "-Wextra"
#pragma GCC diagnostic error "-Wall"
#endif
Paul
- [Cado-nfs-discuss] 2.2.0 build fails on MacOS X 10.9.5, Timothy Geiser, 09/02/2016
- Re: [Cado-nfs-discuss] 2.2.0 build fails on MacOS X 10.9.5, paul zimmermann, 09/05/2016
- Re: [Cado-nfs-discuss] 2.2.0 build fails on MacOS X 10.9.5, Emmanuel Thomé, 09/07/2016
