cado-nfs - Re: [Cado-nfs-discuss] need help on rsa1024
  • To: xiaochun yang <yxc0966@gmail.com>, cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] need help on rsa1024
  • Date: Thu, 08 Sep 2016 07:19:24 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=paul.leyland@gmail.com; spf=Pass smtp.mailfrom=paul.leyland@gmail.com; spf=None smtp.helo=postmaster@mail-wm0-f53.google.com
  • Ironport-phdr: 9a23:s7h7MxLXGTD647G+C9mcpTZWNBhigK39O0sv0rFitYgVK/jxwZ3uMQTl6Ol3ixeRBMOAuqsC1bOd6f65ESxYuNDa4ShEKMQNHzY+yuwu1zQ6B8CEDUCpZNXLVAcdWPp4aVl+4nugOlJUEsutL3fbo3m18CJAUk6nbVk9GO35F8bogtit0KjqotuIMlwO2mP2O+0rZFXu9EOK55FQ2dMjYo8KiTLx6kNSfOpXwW46bXmypD3bovmKwZh47i5LsOgg/cMTGY/zfqA/UKAKRG9+azN9t4XXskzTTAKI7XsBVC0HmxxHS1zU/BqiD8mvmiT/v+t5niKdOJuyBbs9VTPn6alwDRPpkywaLCUR9GDMltc2g6xcuh2s4R152Y/dJo+PZ9RkeaaIRdoHQSJlU9dVXipNStekZpYLSe4MLOJRqYXVqF4HrB/4Dg6pUrC8ggRUj2P7iPVpm98qFhvLiVQt
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
It's undoubtedly possible.
A few tens of years should be sufficient.  You shouldn't need more than an exabyte of disk. and may be able to get away with a few tens of petabytes if you are careful.  120TB of memory is more than adequate for your effort.
You may find this paper helpful in your choice of parameters for the sieving effort.
https://www.researchgate.net/publication/2905152_Factoring_Estimates_for_a_1024-Bit_RSA_Modulus
Good luck with your application.
Paul.
On Thu, 2016-09-08 at 09:29 +0800, xiaochun yang wrote:
I am a newbie of cado-nfs and factoring , I have a chance to use a supercomputer ,the resource I can use is 5000 node .  each node has 12core CPU and 24G memory .
Is it possiable to factoring RSA1024 ? and how long time and how much disk space should I apply for it .
and how to make the params.c309?
_______________________________________________
Cado-nfs-discuss mailing list
Cado-nfs-discuss@lists.gforge.inria.fr
http://lists.gforge.inria.fr/mailman/listinfo/cado-nfs-discuss
