- To: Guy - <pleasechoose@hotmail.com>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] Choosing sieving region - (tasks.I)
- Date: Thu, 06 Apr 2017 11:59:25 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hi Guy,
> From: Guy - <pleasechoose@hotmail.com>
> Date: Thu, 6 Apr 2017 07:51:54 +0000
> Hi,
> I'm trying to run cado on RSA-640 (193 digits), I have a server with 32
> cores and 32GB RAM.
> I've noticed that when sieving the las process takes approx. 3.3GB, this
> limits the sieving to 8-9 cores.
> When running cado-nfs.py the configuration is chosen automatically to the
> rounded-up matching number (params.c195), and the sieving region is defined
> to tasks.I = 15
> I also noticed that params.c190 (closest rounded down matching number)
> defines tasks.I = 14
> According to the parameters documentation (params.c90):
> Increasing I by 1 multiplies the amount of required RAM for the siever by a
> factor of 4.
> As expected, decreasing I to 14, reduces the amount of ram to approx. 1GB,
> which allows me to run sieving on about 30 cores.
> My questions are:
> 1. Why was 15 chosen? what is the penalty for choosing 14 instead? I can
> see that each workunit sieves less (~7000 relations instead of ~17000),
I=15 was chosen since it is close to optimal for this number size
(assuming no memory limit).
> 2. What happens if you decrease task.I during a run? (after some of the
> relations were gathered with I=15) I've noticed that the polynomial
> MurphyE's score is affected by reducing to tasks. does it mean that this
> polynomial is not necessary the best with the new chosen I?
normally changing I during a factorization should not affect the
factorization,
however we do not test this in our regular tests.
> 3. Decreasing to 14 improved sieving by 20% (~230 rels/min instead of ~190
> rels/min)
however since you get less relations per special-q range (7k instead of 17k)
you'll have to sieve for larger special-q's, where the rate of relations per
second will decrease. Also if you decrease I too much, it can happen that you
do not get enough relations, even with very large special-q's.
Another solution is to use 4 threads instead of 2 in las
(tasks.sieve.las.threads=4). This will decrease the average memory
usage per thread, thus you can use more cores of your server.
Best regards,
Paul Zimmermann
PS: note that RSA-640 was already factored in 2005... If you want to factor
numbers in this range, there are some "Smaller-but-Needed" candidates in the
Cunningham project: https://homes.cerias.purdue.edu/~ssw/cun/want131 (please
contact Sam Wagstaff to reserve any of those)
- [Cado-nfs-discuss] Choosing sieving region - (tasks.I), Guy -, 04/06/2017
- Re: [Cado-nfs-discuss] Choosing sieving region - (tasks.I), paul zimmermann, 04/06/2017
