cado-nfs - Re: [Cado-nfs-discuss] Large semiprime factorization
  • To: Pierrick Gaudry <pierrick.gaudry@loria.fr>
  • Subject: Re: [Cado-nfs-discuss] Large semiprime factorization
  • Date: Sat, 8 Apr 2017 22:13:45 -0400
  • Authentication-results: zfront2.inria.fr (amavisd-new); dkim=pass (2048-bit key) header.d=gmail.com
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=earlfechter@gmail.com; spf=Pass smtp.mailfrom=earlfechter@gmail.com; spf=None smtp.helo=postmaster@mail-qk0-f181.google.com
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
  • Resent-date: Sun, 9 Apr 2017 08:55:05 +0200
  • Resent-from: Pierrick Gaudry <gaudry@bratwurst>
  • Resent-message-id: <20170409065505.k45zltiedithquzx@bratwurst>
  • Resent-to: cado-nfs-discuss@lists.gforge.inria.fr
No, I don't. But I'm planning on using a bunch of jailbroken iphones as
slaves to my desktop computer. I know I'll realistically have a very slim
chance of splitting the number with my home computer, but I'm doing it like
the lottery: you know you probably wont win, but that doesn't keep you from
trying.
About that parameter: what IS a parameter, and how do you find one?
H.S freshman, not the world's best mathematician, lol.
Help would be appreciated,
-E
Sent from my iPhone
> On Apr 8, 2017, at 2:09 PM, Pierrick Gaudry <pierrick.gaudry@loria.fr>
> wrote:
> Cado-nfs requires a parameter file for each size of number to be factored
> (even if you try to factor a prime ;-)). If you give a number of, say,
> 1024 bits, then there is no parameter file and it won't even try.
> You can try to craft a parameter file by extrapolating from what is
> already is parameters/factor, but don't expect miracles: if there is no
> parameter file, then we didn't test this size, and for sure there will be
> problems...
> I guess you have access to huge computing resources to hope to factor a
> number larger than the available parameters, don't you?
> Pierrick
>> On Sat, Apr 08, 2017 at 12:40:21PM -0400, Earl Fechter wrote:
>> Im trying to factor a large prime. Cado nfs wont even try. How do I make
>> CADO do what I want?
>> Sent from my iPhone
>> _______________________________________________
>> Cado-nfs-discuss mailing list
>> Cado-nfs-discuss@lists.gforge.inria.fr
>> https://lists.gforge.inria.fr/mailman/listinfo/cado-nfs-discuss
