cado-nfs - [Cado-nfs-discuss] OpenMPI trouble
  • To: cado-nfs-discuss <cado-nfs-discuss@lists.gforge.inria.fr>
  • Subject: [Cado-nfs-discuss] OpenMPI trouble
  • Date: Thu, 20 Apr 2017 00:29:36 +0300
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=hbobrov@yandex.ru; spf=Pass smtp.mailfrom=hbobrov@yandex.ru; spf=None smtp.helo=postmaster@forward8m.cmail.yandex.net
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Previously, I used MPICH2 to launch my application. But recently I had to use
openmpi and when I started on 2 nodes, it gives an error:
Open MPI detected an inbound MPI TCP connection request from a peer that
appears to be part of this MPI job (i.e., it identified itself as part of
this Open MPI job), but it is from an IP address that is unexpected. This is
highly unusual.
The inbound connection has been dropped, and the peer should simply try again
with a different IP interface (i.e., the job should hopefully be able to
continue).
Local host: node2
Local PID: 6029
Peer hostname: node2([[40861,1],2])
Source IP of socket:192.168.122.1
Known IPs of peer:
I run mpiexec -np 4 -machinefile ./hostfile ./test_hello mpi=2x2.
Contents of the file hostfile:
192.168.56.1 slots=2
192.168.56.2 slots=2
Whats the problem?
Best regards
Бобров Х.
