- To: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: [Cado-nfs-discuss] Using cado-nfs to DLP a p270
- Date: Sat, 10 Jun 2017 10:25:02 +1200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=peter@crypt.co.nz; spf=Pass smtp.mailfrom=peter@crypt.co.nz; spf=None smtp.helo=postmaster@mail-oi0-f43.google.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
I'm not 100% sure if I am doing the right thing so I thought I would ask here to confirm.
I'm looking to factor a p270 with a fixed generator.P 12824716....
G 2
Y 8990799.....
Then the command line I would use would be:
./cado-nfs.py 12824716... -dlp -ell 8990799.. -gfpext 2
And see if any primes come out of factoring the prime and then sieve the ell.
Or am I misunderstanding how I would achieve this as I am not sure how I would setup the hints if I wasn't using the gfpext = 2 which is the generator value.
Cheers
Peter
- [Cado-nfs-discuss] Using cado-nfs to DLP a p270, Peter Lambrechtsen, 06/10/2017
- Re: [Cado-nfs-discuss] Using cado-nfs to DLP a p270, Pierrick Gaudry, 06/10/2017
- Re: [Cado-nfs-discuss] Using cado-nfs to DLP a p270, paul zimmermann, 06/10/2017
