- From: Anderson Felipe Jimenez Guevara <afjimenez@unimayor.edu.co>
- To: Emmanuel Thomé <emmanuel.thome@inria.fr>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] Freeze on Square Root
- Date: Tue, 5 Sep 2017 13:28:05 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=afjimenez@unimayor.edu.co; spf=Pass smtp.mailfrom=afjimenez@unimayor.edu.co; spf=None smtp.helo=postmaster@mail-lf0-f53.google.com
- Ironport-phdr: 9a23:VF6Spx9ChNodqP9uRHKM819IXTAuvvDOBiVQ1KB90e8cTK2v8tzYMVDF4r011RmSAtWdtqoMotGVmp6jcFRI2YyGvnEGfc4EfD4+ouJSoTYdBtWYA1bwNv/gYn9yNs1DUFh44yPzahANS47WLmffqXyq7DMUBg63dU8sfry0ScbuiJGa0uW7/YDeZzJ0hD244PsmIRCzpAPMu81QnYtlL6sZyx3To3IOdf4Alk1yIlfGthDw692r+5gr3SlUuuosv+xBVKj8crZwYqFVEj08Oihh7cPptBzOSwadzmYaU2Afgx1SRQXJ8VfxWcGi4WPBquNh1XzCboXNRrcuVGHntv8zRQ==
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hi, this device have 1GB RAM, and I don't have a c105.sqrt.log yet, but I have a file named c105.sqrt.stdout.1 this is the output:
relations in 0.1s -- 1.1 MB/s -- 13270.6 rels/s # Read 2048 relations in 0.1s -- 2.2 MB/s -- 25968.1 rels/s # Read 4096 relations in 0.1s -- 4.3 MB/s -- 50214.6 rels/s # Read 8192 relations in 0.2s -- 4.0 MB/s -- 46283.5 rels/s # Read 16384 relations in 0.3s -- 5.2 MB/s -- 60356.4 rels/s# Read 32768 relations in 0.4s -- 6.8 MB/s -- 79373.1 rels/s# Read 65536 relations in 0.9s -- 6.1 MB/s -- 70366.4 rels/s# Read 131072 relations in 2.6s -- 4.3 MB/s -- 50073.5 rels$# Read 262144 relations in 6.6s -- 3.4 MB/s -- 39423.8 rels$# Read 524288 relations in 15.1s -- 3.0 MB/s -- 34641.6 rel$# Done: Read 876946 relations in 27.1s -- 2.8 MB/s -- 32342$
Thanks
El 5 sept. 2017 13:11, "Emmanuel Thomé" <emmanuel.thome@inria.fr> escribió:
Hi.
Thanks for your report.
How much ram do you have on that box? What does "top" look like while sqrt is running ? Can you post the contents of the file cXXX.sqrt.log (XXX is probably 105) from the run's data directory ? (By default it's some /tmp/cXXX.XXXXXX).
E.--
On September 5, 2017 8:05:06 PM GMT+02:00, Anderson Felipe Jimenez Guevara <afjimenez@unimayor.edu.co> wrote:Hello, how are you, my error is in the square root step, I'm working on a Raspberry Pi 3, and I'm trying to factorize a number of 103 digits, The problem is that step is freeze:5 12:51:46 2017 [0.723 s/iter] Info:Linear Algebra: krylov: N=7000 ; ETA (N=8000): Tue Sep 5 12:52:14 2017 [0.726 s/iter] Info:Linear Algebra: krylov: N=8000 ; ETA (N=8000): Tue Sep 5 12:52:38 2017 [0.729 s/iter] Info:Linear Algebra: lingen ETA: Tue Sep 5 12:53:05 2017 Info:Linear Algebra: lingen ETA: Tue Sep 5 12:57:26 2017 Info:Linear Algebra: lingen ETA: Tue Sep 5 12:57:18 2017 Info:Linear Algebra: lingen ETA: Tue Sep 5 12:56:11 2017 Info:Linear Algebra: lingen ETA: Tue Sep 5 13:00:48 2017 Info:Linear Algebra: lingen ETA: Tue Sep 5 13:00:57 2017 Info:Linear Algebra: lingen ETA: Tue Sep 5 13:00:59 2017 Info:Linear Algebra: lingen ETA: Tue Sep 5 13:01:07 2017 Info:Linear Algebra: lingen ETA: Tue Sep 5 13:01:09 2017 Info:Linear Algebra: lingen ETA: Tue Sep 5 13:01:15 2017 Info:Linear Algebra: lingen ETA: Tue Sep 5 13:13:13 2017 Info:Linear Algebra: lingen ETA: Tue Sep 5 13:13:32 2017 Info:Linear Algebra: lingen ETA: Tue Sep 5 13:13:35 2017 Info:Linear Algebra: lingen ETA: Tue Sep 5 13:14:34 2017 Info:Linear Algebra: lingen ETA: Tue Sep 5 13:02:50 2017 Info:Linear Algebra: lingen ETA: Tue Sep 5 13:03:26 2017 Info:Linear Algebra: lingen ETA: Tue Sep 5 13:03:40 2017 Info:Linear Algebra: lingen ETA: Tue Sep 5 13:03:49 2017 Info:Linear Algebra: lingen ETA: Tue Sep 5 13:03:33 2017 Info:Linear Algebra: lingen ETA: Tue Sep 5 13:03:08 2017 Info:Linear Algebra: lingen ETA: Tue Sep 5 13:04:41 2017 Info:Linear Algebra: lingen ETA: Tue Sep 5 13:05:08 2017 Info:Linear Algebra: lingen ETA: Tue Sep 5 13:03:43 2017 Info:Linear Algebra: lingen ETA: Tue Sep 5 13:02:01 2017 Info:Linear Algebra: mksol: N=1000 ; ETA (N=4000): Tue Sep5 13:54:52 2017 [0.795 s/iter] Info:Linear Algebra: mksol: N=2000 ; ETA (N=4000): Tue Sep5 13:55:12 2017 [0.800 s/iter] Info:Linear Algebra: mksol: N=3000 ; ETA (N=4000): Tue Sep5 13:55:20 2017 [0.802 s/iter] Info:Linear Algebra: mksol: N=4000 ; ETA (N=4000): Tue Sep5 13:55:12 2017 [0.800 s/iter] Info:Quadratic Characters: Starting Info:Square Root: Starting Info:Square Root: Creating file of (a,b) values----------------------------GCC -v outputUsing built-in specs.COLLECT_GCC=gccCOLLECT_LTO_WRAPPER=/usr/lib/gcc/arm-linux-gnueabihf/6/lto-wrapperTarget: arm-linux-gnueabihfConfigured with: ../src/configure -v --with-pkgversion='Raspbian 6.3.0-18+rpi1' --with-bugurl=file:///usr/share/doc/gcc-6/README.Bugs --enable-languages=c,ada,c++,java,go,d,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-6 --program-prefix=arm-linux-gnueabihf- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-libitm --disable-libquadmath --enable-plugin --with-system-zlib --disable-browser-plugin --enable-java-awt=gtk --enable-gtk-cairo --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-6-armhf/jre --enable-java-home --with-jvm-root-dir=/usr/lib/jvm/java-1.5.0-gcj-6-armhf --with-jvm-jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-6-armhf --with-arch-directory=arm --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --with-target-system-zlib --enable-objc-gc=auto --enable-multiarch --disable-sjlj-exceptions --with-arch=armv6 --with-fpu=vfp --with-float=hard --enable-checking=release --build=arm-linux-gnueabihf --host=arm-linux-gnueabihf --target=arm-linux-gnueabihfThread model: posixgcc version 6.3.0 20170516 (Raspbian 6.3.0-18+rpi1)----------------------------------------I'm using the development and 2.2.0 version, this does not happen with samller numbers.Thanks and sorry for my bad English
Sent from my phone. Please excuse brevity and misspellings.
- [Cado-nfs-discuss] Freeze on Square Root, Anderson Felipe Jimenez Guevara, 09/05/2017
- Re: [Cado-nfs-discuss] Freeze on Square Root, Emmanuel Thomé, 09/05/2017
- Re: [Cado-nfs-discuss] Freeze on Square Root, Anderson Felipe Jimenez Guevara, 09/05/2017
- Re: [Cado-nfs-discuss] Freeze on Square Root, paul zimmermann, 09/05/2017
