- From: Anderson Felipe Jimenez Guevara <afjimenez@unimayor.edu.co>
- To: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: [Cado-nfs-discuss] Square Root Freeze
- Date: Sun, 10 Sep 2017 20:51:18 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=afjimenez@unimayor.edu.co; spf=Pass smtp.mailfrom=afjimenez@unimayor.edu.co; spf=None smtp.helo=postmaster@mail-lf0-f54.google.com
- Ironport-phdr: 9a23:z9Gw2hKYrvBEn/pSvtmcpTZWNBhigK39O0sv0rFitYgUKv3xwZ3uMQTl6Ol3ixeRBMOAtKIC1rKempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBWB6kG1uDUbFhK6MwRuY+j0AYXPlN+f0+Gp54aVbAtPnjWwJ7J0NhS/6wvL5ecMho43A6A9xwHSpX0AVelSxHtlbXCSmhv669X404Nu7S1Ksrp1/sBCUKD3eakqZaFeDTEvImcvosDnqF/ISl3ctTMnTmwKn08QUED+5xbgU8Kpvw==
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
---------- Mensaje reenviado ----------
De: "Anderson Felipe Jimenez Guevara" <afjimenez@unimayor.edu.co>
Fecha: 9 sept. 2017 12:50
Asunto: Re: [Cado-nfs-discuss] Square Root Freeze
Para: "paul zimmermann" <Paul.Zimmermann@inria.fr>
Cc:
Cc:
Hello, This is the content of my ./cado-nfs.py command line:...[32;1mInfo [0m:root: Using default parameter file ./parameters/factor/params.c105[32;1mInfo [0m:root: Set tasks.threads=4 based on detected physical cpus[32;1mInfo [0m:root: tasks.polyselect.threads = 2[32;1mInfo [0m:root: tasks.sieve.sieving.threads = 2[32;1mInfo [0m:root: slaves.scriptpath is /home/pi/cado-nfs-2.2.0[32;1mInfo [0m:root: Command line parameters: ./cado-nfs.py 1840931355870932188289631718789795268691628113013458775870513368017096038404806450081242498103191807777 workdir=/tmp/c105[32;1mInfo [0m:root: If this computation gets interrupted, it can be resumed with ./cado-nfs.py /tmp/c105/c105.parameters_snapshot.0[32;1mInfo [0m:Server Launcher: Adding Master to whitelist to allow clients on localhost to connect[32;1mInfo [0m:HTTP server: Using non-threaded HTTPS server[32;1mInfo [0m:HTTP server: Using whitelist: localhost,Master[32;1mInfo [0m:Complete Factorization: Factoring 1840931355870932188289631718789795268691628113013458775870513368017096038404806450081242498103191807777[32;1mInfo [0m:HTTP server: serving at https://Master:40103 (0.0.0.0)[32;1mInfo [0m:HTTP server: For debugging purposes, the URL above can be accessed if the server._only_registered_=False parameter is added[32;1mInfo [0m:HTTP server: You can start additional cado-nfs-client.py scripts with parameters: --server=https://Master:40103 --certsha1=d51efc5d2ac27128eb42ba114255450f44576fda[32;1mInfo [0m:HTTP server: If you want to start additional clients, remember to add their hosts to server.whitelist[32;1mInfo [0m:Client Launcher: Starting client id localhost on host localhost[32;1mInfo [0m:Client Launcher: Starting client id localhost+2 on host localhost[32;1mInfo [0m:Client Launcher: Running clients: localhost (Host localhost, PID 885), localhost+2 (Host localhost, PID 888)[32;1mInfo [0m:Polynomial Selection (size optimized): Starting[32;1mInfo [0m:Polynomial Selection (size optimized): 0 polynomials in queue from previous run[32;1mInfo [0m:Polynomial Selection (size optimized): Adding workunit c105_polyselect1_0-10000 to database[32;1mInfo [0m:Polynomial Selection (size optimized): Adding workunit c105_polyselect1_10000-20000 to database[32;1mInfo [0m:Polynomial Selection (size optimized): Adding workunit c105_polyselect1_20000-30000 to database[32;1mInfo [0m:Polynomial Selection (size optimized): Adding workunit c105_polyselect1_30000-40000 to database[32;1mInfo [0m:Polynomial Selection (size optimized): Adding workunit c105_polyselect1_40000-50000 to database[32;1mInfo [0m:Polynomial Selection (size optimized): Adding workunit c105_polyselect1_50000-60000 to database[32;1mInfo [0m:Polynomial Selection (size optimized): Adding workunit c105_polyselect1_60000-70000 to database[32;1mInfo [0m:Polynomial Selection (size optimized): Adding workunit c105_polyselect1_70000-80000 to database[32;1mInfo [0m:Polynomial Selection (size optimized): Adding workunit c105_polyselect1_80000-90000 to database[32;1mInfo [0m:Polynomial Selection (size optimized): Adding workunit c105_polyselect1_90000-100000 to database[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect1_0-10000 to client localhost[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect1_10000-20000 to client localhost+2[32;1mInfo [0m:Polynomial Selection (size optimized): Adding workunit c105_polyselect1_100000-110000 to database[32;1mInfo [0m:Polynomial Selection (size optimized): Adding workunit c105_polyselect1_110000-120000 to database[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect1_20000-30000 to client localhost[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect1_30000-40000 to client localhost+2[32;1mInfo [0m:Polynomial Selection (size optimized): Parsed 368 polynomials, added 155 to priority queue (has 50)[32;1mInfo [0m:Polynomial Selection (size optimized): Worst polynomial in queue now has lognorm 37.230000[32;1mInfo [0m:Polynomial Selection (size optimized): Marking workunit c105_polyselect1_0-10000 as ok (4.0% => ETA Sat Sep 9 03:53:15 2017)[32;1mInfo [0m:Polynomial Selection (size optimized): Adding workunit c105_polyselect1_120000-130000 to database[32;1mInfo [0m:Polynomial Selection (size optimized): Adding workunit c105_polyselect1_130000-140000 to database[32;1mInfo [0m:Polynomial Selection (size optimized): Parsed 332 polynomials, added 34 to priority queue (has 50)[32;1mInfo [0m:Polynomial Selection (size optimized): Worst polynomial in queue now has lognorm 36.680000[32;1mInfo [0m:Polynomial Selection (size optimized): Marking workunit c105_polyselect1_10000-20000 as ok (8.0% => ETA Sat Sep 9 03:29:10 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect1_40000-50000 to client localhost+2[32;1mInfo [0m:Polynomial Selection (size optimized): Parsed 330 polynomials, added 22 to priority queue (has 50)[32;1mInfo [0m:Polynomial Selection (size optimized): Worst polynomial in queue now has lognorm 36.300000[32;1mInfo [0m:Polynomial Selection (size optimized): Marking workunit c105_polyselect1_30000-40000 as ok (12.0% => ETA Sat Sep 9 03:35:12 2017)[32;1mInfo [0m:Polynomial Selection (size optimized): Adding workunit c105_polyselect1_140000-150000 to database[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect1_50000-60000 to client localhost[32;1mInfo [0m:Polynomial Selection (size optimized): Adding workunit c105_polyselect1_150000-160000 to database[32;1mInfo [0m:Polynomial Selection (size optimized): Parsed 337 polynomials, added 16 to priority queue (has 50)[32;1mInfo [0m:Polynomial Selection (size optimized): Worst polynomial in queue now has lognorm 36.090000[32;1mInfo [0m:Polynomial Selection (size optimized): Marking workunit c105_polyselect1_20000-30000 as ok (16.0% => ETA Sat Sep 9 03:27:45 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect1_60000-70000 to client localhost[32;1mInfo [0m:Polynomial Selection (size optimized): Adding workunit c105_polyselect1_160000-170000 to database[32;1mInfo [0m:Polynomial Selection (size optimized): Parsed 316 polynomials, added 10 to priority queue (has 50)[32;1mInfo [0m:Polynomial Selection (size optimized): Worst polynomial in queue now has lognorm 35.930000[32;1mInfo [0m:Polynomial Selection (size optimized): Marking workunit c105_polyselect1_50000-60000 as ok (20.0% => ETA Sat Sep 9 03:31:43 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect1_70000-80000 to client localhost+2[32;1mInfo [0m:Polynomial Selection (size optimized): Adding workunit c105_polyselect1_170000-180000 to database[32;1mInfo [0m:Polynomial Selection (size optimized): Parsed 373 polynomials, added 12 to priority queue (has 50)[32;1mInfo [0m:Polynomial Selection (size optimized): Worst polynomial in queue now has lognorm 35.780000[32;1mInfo [0m:Polynomial Selection (size optimized): Marking workunit c105_polyselect1_40000-50000 as ok (24.0% => ETA Sat Sep 9 03:27:56 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect1_80000-90000 to client localhost[32;1mInfo [0m:Polynomial Selection (size optimized): Adding workunit c105_polyselect1_180000-190000 to database[32;1mInfo [0m:Polynomial Selection (size optimized): Parsed 304 polynomials, added 8 to priority queue (has 50)[32;1mInfo [0m:Polynomial Selection (size optimized): Worst polynomial in queue now has lognorm 35.690000[32;1mInfo [0m:Polynomial Selection (size optimized): Marking workunit c105_polyselect1_60000-70000 as ok (28.0% => ETA Sat Sep 9 03:30:00 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect1_90000-100000 to client localhost+2[32;1mInfo [0m:Polynomial Selection (size optimized): Adding workunit c105_polyselect1_190000-200000 to database[32;1mInfo [0m:Polynomial Selection (size optimized): Parsed 342 polynomials, added 9 to priority queue (has 50)[32;1mInfo [0m:Polynomial Selection (size optimized): Worst polynomial in queue now has lognorm 35.560000[32;1mInfo [0m:Polynomial Selection (size optimized): Marking workunit c105_polyselect1_70000-80000 as ok (32.0% => ETA Sat Sep 9 03:27:54 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect1_100000-110000 to client localhost[32;1mInfo [0m:Polynomial Selection (size optimized): Adding workunit c105_polyselect1_200000-210000 to database[32;1mInfo [0m:Polynomial Selection (size optimized): Parsed 324 polynomials, added 2 to priority queue (has 50)[32;1mInfo [0m:Polynomial Selection (size optimized): Worst polynomial in queue now has lognorm 35.540000[32;1mInfo [0m:Polynomial Selection (size optimized): Marking workunit c105_polyselect1_80000-90000 as ok (36.0% => ETA Sat Sep 9 03:29:11 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect1_110000-120000 to client localhost+2[32;1mInfo [0m:Polynomial Selection (size optimized): Adding workunit c105_polyselect1_210000-220000 to database[32;1mInfo [0m:Polynomial Selection (size optimized): Parsed 336 polynomials, added 2 to priority queue (has 50)[32;1mInfo [0m:Polynomial Selection (size optimized): Worst polynomial in queue now has lognorm 35.520000[32;1mInfo [0m:Polynomial Selection (size optimized): Marking workunit c105_polyselect1_90000-100000 as ok (40.0% => ETA Sat Sep 9 03:27:40 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect1_120000-130000 to client localhost[32;1mInfo [0m:Polynomial Selection (size optimized): Adding workunit c105_polyselect1_220000-230000 to database[32;1mInfo [0m:Polynomial Selection (size optimized): Parsed 336 polynomials, added 3 to priority queue (has 50)[32;1mInfo [0m:Polynomial Selection (size optimized): Worst polynomial in queue now has lognorm 35.510000[32;1mInfo [0m:Polynomial Selection (size optimized): Marking workunit c105_polyselect1_100000-110000 as ok (44.0% => ETA Sat Sep 9 03:28:53 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect1_130000-140000 to client localhost+2[32;1mInfo [0m:Polynomial Selection (size optimized): Adding workunit c105_polyselect1_230000-240000 to database[32;1mInfo [0m:Polynomial Selection (size optimized): Parsed 290 polynomials, added 2 to priority queue (has 50)[32;1mInfo [0m:Polynomial Selection (size optimized): Worst polynomial in queue now has lognorm 35.460000[32;1mInfo [0m:Polynomial Selection (size optimized): Marking workunit c105_polyselect1_110000-120000 as ok (48.0% => ETA Sat Sep 9 03:27:15 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect1_140000-150000 to client localhost[32;1mInfo [0m:Polynomial Selection (size optimized): Adding workunit c105_polyselect1_240000-250000 to database[32;1mInfo [0m:Polynomial Selection (size optimized): Parsed 315 polynomials, added 1 to priority queue (has 50)[32;1mInfo [0m:Polynomial Selection (size optimized): Worst polynomial in queue now has lognorm 35.430000[32;1mInfo [0m:Polynomial Selection (size optimized): Marking workunit c105_polyselect1_120000-130000 as ok (52.0% => ETA Sat Sep 9 03:28:27 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect1_150000-160000 to client localhost+2[32;1mInfo [0m:Polynomial Selection (size optimized): Parsed 342 polynomials, added 3 to priority queue (has 50)[32;1mInfo [0m:Polynomial Selection (size optimized): Worst polynomial in queue now has lognorm 35.380000[32;1mInfo [0m:Polynomial Selection (size optimized): Marking workunit c105_polyselect1_130000-140000 as ok (56.0% => ETA Sat Sep 9 03:27:17 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect1_160000-170000 to client localhost[32;1mInfo [0m:Polynomial Selection (size optimized): Parsed 339 polynomials, added 2 to priority queue (has 50)[32;1mInfo [0m:Polynomial Selection (size optimized): Worst polynomial in queue now has lognorm 35.370000[32;1mInfo [0m:Polynomial Selection (size optimized): Marking workunit c105_polyselect1_140000-150000 as ok (60.0% => ETA Sat Sep 9 03:28:14 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect1_170000-180000 to client localhost+2[32;1mInfo [0m:Polynomial Selection (size optimized): Parsed 352 polynomials, added 1 to priority queue (has 50)[32;1mInfo [0m:Polynomial Selection (size optimized): Worst polynomial in queue now has lognorm 35.360000[32;1mInfo [0m:Polynomial Selection (size optimized): Marking workunit c105_polyselect1_150000-160000 as ok (64.0% => ETA Sat Sep 9 03:27:17 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect1_180000-190000 to client localhost[32;1mInfo [0m:Polynomial Selection (size optimized): Parsed 313 polynomials, added 0 to priority queue (has 50)[32;1mInfo [0m:Polynomial Selection (size optimized): Marking workunit c105_polyselect1_160000-170000 as ok (68.0% => ETA Sat Sep 9 03:28:04 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect1_190000-200000 to client localhost+2[32;1mInfo [0m:Polynomial Selection (size optimized): Parsed 297 polynomials, added 2 to priority queue (has 50)[32;1mInfo [0m:Polynomial Selection (size optimized): Worst polynomial in queue now has lognorm 35.350000[32;1mInfo [0m:Polynomial Selection (size optimized): Marking workunit c105_polyselect1_170000-180000 as ok (72.0% => ETA Sat Sep 9 03:27:04 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect1_200000-210000 to client localhost[32;1mInfo [0m:Polynomial Selection (size optimized): Parsed 325 polynomials, added 4 to priority queue (has 50)[32;1mInfo [0m:Polynomial Selection (size optimized): Worst polynomial in queue now has lognorm 35.250000[32;1mInfo [0m:Polynomial Selection (size optimized): Marking workunit c105_polyselect1_180000-190000 as ok (76.0% => ETA Sat Sep 9 03:27:54 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect1_210000-220000 to client localhost+2[32;1mInfo [0m:Polynomial Selection (size optimized): Parsed 325 polynomials, added 1 to priority queue (has 50)[32;1mInfo [0m:Polynomial Selection (size optimized): Worst polynomial in queue now has lognorm 35.230000[32;1mInfo [0m:Polynomial Selection (size optimized): Marking workunit c105_polyselect1_190000-200000 as ok (80.0% => ETA Sat Sep 9 03:27:06 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect1_220000-230000 to client localhost[32;1mInfo [0m:Polynomial Selection (size optimized): Parsed 344 polynomials, added 2 to priority queue (has 50)[32;1mInfo [0m:Polynomial Selection (size optimized): Worst polynomial in queue now has lognorm 35.210000[32;1mInfo [0m:Polynomial Selection (size optimized): Marking workunit c105_polyselect1_200000-210000 as ok (84.0% => ETA Sat Sep 9 03:27:48 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect1_230000-240000 to client localhost+2[32;1mInfo [0m:Polynomial Selection (size optimized): Parsed 321 polynomials, added 1 to priority queue (has 50)[32;1mInfo [0m:Polynomial Selection (size optimized): Worst polynomial in queue now has lognorm 35.200000[32;1mInfo [0m:Polynomial Selection (size optimized): Marking workunit c105_polyselect1_210000-220000 as ok (88.0% => ETA Sat Sep 9 03:27:01 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect1_240000-250000 to client localhost[32;1mInfo [0m:Polynomial Selection (size optimized): Parsed 362 polynomials, added 2 to priority queue (has 50)[32;1mInfo [0m:Polynomial Selection (size optimized): Worst polynomial in queue now has lognorm 35.160000[32;1mInfo [0m:Polynomial Selection (size optimized): Marking workunit c105_polyselect1_220000-230000 as ok (92.0% => ETA Sat Sep 9 03:27:52 2017)[32;1mInfo [0m:Polynomial Selection (size optimized): Parsed 345 polynomials, added 1 to priority queue (has 50)[32;1mInfo [0m:Polynomial Selection (size optimized): Worst polynomial in queue now has lognorm 35.150000[32;1mInfo [0m:Polynomial Selection (size optimized): Marking workunit c105_polyselect1_230000-240000 as ok (96.0% => ETA Sat Sep 9 03:27:00 2017)[32;1mInfo [0m:Polynomial Selection (size optimized): Parsed 300 polynomials, added 1 to priority queue (has 50)[32;1mInfo [0m:Polynomial Selection (size optimized): Worst polynomial in queue now has lognorm 35.120000[32;1mInfo [0m:Polynomial Selection (size optimized): Marking workunit c105_polyselect1_240000-250000 as ok (100.0% => ETA Sat Sep 9 03:27:36 2017)[32;1mInfo [0m:Polynomial Selection (size optimized): Finished[32;1mInfo [0m:Polynomial Selection (root optimized): Starting[32;1mInfo [0m:Polynomial Selection (root optimized): No polynomial was previously found[32;1mInfo [0m:Polynomial Selection (root optimized): Adding workunit c105_polyselect2_0 to database[32;1mInfo [0m:Polynomial Selection (root optimized): Adding workunit c105_polyselect2_6 to database[32;1mInfo [0m:Polynomial Selection (root optimized): Adding workunit c105_polyselect2_12 to database[32;1mInfo [0m:Polynomial Selection (root optimized): Adding workunit c105_polyselect2_18 to database[32;1mInfo [0m:Polynomial Selection (root optimized): Adding workunit c105_polyselect2_24 to database[32;1mInfo [0m:Polynomial Selection (root optimized): Adding workunit c105_polyselect2_30 to database[32;1mInfo [0m:Polynomial Selection (root optimized): Adding workunit c105_polyselect2_36 to database[32;1mInfo [0m:Polynomial Selection (root optimized): Adding workunit c105_polyselect2_42 to database[32;1mInfo [0m:Polynomial Selection (root optimized): Adding workunit c105_polyselect2_48 to database[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect2_0 to client localhost[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect2_6 to client localhost+2[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect2_12 to client localhost+2[32;1mInfo [0m:Polynomial Selection (root optimized): New best polynomial from file /tmp/c105/c105.upload/c105.polyselect2.4xnfpxpp.opt_6: Murphy E = 3.63e-09[32;1mInfo [0m:Polynomial Selection (root optimized): Marking workunit c105_polyselect2_6 as ok (4.0% => ETA Sat Sep 9 05:02:32 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect2_18 to client localhost[32;1mInfo [0m:Polynomial Selection (root optimized): Best polynomial from file /tmp/c105/c105.upload/c105.polyselect2.q2056pot.opt_0 with E=3.59e-09 is no better than current best with E=3.63e-09[32;1mInfo [0m:Polynomial Selection (root optimized): Marking workunit c105_polyselect2_0 as ok (16.0% => ETA Sat Sep 9 03:51:39 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect2_24 to client localhost+2[32;1mInfo [0m:Polynomial Selection (root optimized): New best polynomial from file /tmp/c105/c105.upload/c105.polyselect2._cq2g2pc.opt_12: Murphy E = 3.72e-09[32;1mInfo [0m:Polynomial Selection (root optimized): Marking workunit c105_polyselect2_12 as ok (28.0% => ETA Sat Sep 9 03:54:06 2017)[32;1mInfo [0m:Polynomial Selection (root optimized): New best polynomial from file /tmp/c105/c105.upload/c105.polyselect2.blv95z_c.opt_18: Murphy E = 4.18e-09[32;1mInfo [0m:Polynomial Selection (root optimized): Marking workunit c105_polyselect2_18 as ok (40.0% => ETA Sat Sep 9 03:46:22 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect2_30 to client localhost[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect2_36 to client localhost[32;1mInfo [0m:Polynomial Selection (root optimized): New best polynomial from file /tmp/c105/c105.upload/c105.polyselect2.fgp8jr11.opt_30: Murphy E = 4.42e-09[32;1mInfo [0m:Polynomial Selection (root optimized): Marking workunit c105_polyselect2_30 as ok (52.0% => ETA Sat Sep 9 03:48:04 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect2_42 to client localhost+2[32;1mInfo [0m:Polynomial Selection (root optimized): Best polynomial from file /tmp/c105/c105.upload/c105.polyselect2.h3fk8u1w.opt_24 with E=3.61e-09 is no better than current best with E=4.42e-09[32;1mInfo [0m:Polynomial Selection (root optimized): Marking workunit c105_polyselect2_24 as ok (64.0% => ETA Sat Sep 9 03:44:56 2017)[32;1mInfo [0m:Polynomial Selection (root optimized): New best polynomial from file /tmp/c105/c105.upload/c105.polyselect2.9l212opy.opt_36: Murphy E = 4.93e-09[32;1mInfo [0m:Polynomial Selection (root optimized): Marking workunit c105_polyselect2_36 as ok (76.0% => ETA Sat Sep 9 03:46:10 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_polyselect2_48 to client localhost[32;1mInfo [0m:Polynomial Selection (root optimized): Best polynomial from file /tmp/c105/c105.upload/c105.polyselect2.moj45_wy.opt_42 with E=3.69e-09 is no better than current best with E=4.93e-09[32;1mInfo [0m:Polynomial Selection (root optimized): Marking workunit c105_polyselect2_42 as ok (88.0% => ETA Sat Sep 9 03:44:24 2017)[32;1mInfo [0m:Polynomial Selection (root optimized): Best polynomial from file /tmp/c105/c105.upload/c105.polyselect2.qggo9h6x.opt_48 with E=3.02e-09 is no better than current best with E=4.93e-09[32;1mInfo [0m:Polynomial Selection (root optimized): Marking workunit c105_polyselect2_48 as ok (100.0% => ETA Sat Sep 9 03:42:42 2017)[32;1mInfo [0m:Polynomial Selection (root optimized): Finished, best polynomial from file /tmp/c105/c105.upload/c105.polyselect2.9l212opy.opt_36 has Murphy_E = 4.93e-09[32;1mInfo [0m:Polynomial Selection (root optimized): Best overall polynomial was 20-th in list after size optimization[32;1mInfo [0m:Generate Factor Base: Starting[32;1mInfo [0m:Generate Factor Base: Finished[32;1mInfo [0m:Generate Free Relations: Starting[32;1mInfo [0m:Generate Free Relations: Found 86114 free relations[32;1mInfo [0m:Generate Free Relations: Finished[32;1mInfo [0m:Lattice Sieving: Starting[32;1mInfo [0m:Lattice Sieving: We want 3485434 relations[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1059970-1064970 to database[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1064970-1069970 to database[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1069970-1074970 to database[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1074970-1079970 to database[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1079970-1084970 to database[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1084970-1089970 to database[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1089970-1094970 to database[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1094970-1099970 to database[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1099970-1104970 to database[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1104970-1109970 to database[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1059970-1064970 to client localhost[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1064970-1069970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1109970-1114970 to database[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1114970-1119970 to database[33;1mWarning [0m:HTTP server: 127.0.0.1 Connection error: [Errno 32] Broken pipe[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1069970-1074970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1119970-1124970 to database[32;1mInfo [0m:Lattice Sieving: Found 27753 relations in '/tmp/c105/c105.upload/c105.sieving.1064970-1069970.ybwqu0w2.gz', total is now 27753/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1064970-1069970 as ok (0.8% => ETA Sat Sep 9 21:52:25 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1074970-1079970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1124970-1129970 to database[32;1mInfo [0m:Lattice Sieving: Found 30586 relations in '/tmp/c105/c105.upload/c105.sieving.1059970-1064970.tunegg53.gz', total is now 58339/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1059970-1064970 as ok (1.7% => ETA Sat Sep 9 13:19:27 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1079970-1084970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1129970-1134970 to database[32;1mInfo [0m:Lattice Sieving: Found 28106 relations in '/tmp/c105/c105.upload/c105.sieving.1069970-1074970.zay1zepr.gz', total is now 86445/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1069970-1074970 as ok (2.5% => ETA Sat Sep 9 15:28:16 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1084970-1089970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1134970-1139970 to database[32;1mInfo [0m:Lattice Sieving: Found 27512 relations in '/tmp/c105/c105.upload/c105.sieving.1074970-1079970.r9dvg33x.gz', total is now 113957/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1074970-1079970 as ok (3.3% => ETA Sat Sep 9 13:02:37 2017)[32;1mInfo [0m:Lattice Sieving: Found 27931 relations in '/tmp/c105/c105.upload/c105.sieving.1079970-1084970.34ynjnt4.gz', total is now 141888/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1079970-1084970 as ok (4.1% => ETA Sat Sep 9 14:30:03 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1089970-1094970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1139970-1144970 to database[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1094970-1099970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1144970-1149970 to database[32;1mInfo [0m:Lattice Sieving: Found 26134 relations in '/tmp/c105/c105.upload/c105.sieving.1084970-1089970.hk690tzt.gz', total is now 168022/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1084970-1089970 as ok (4.8% => ETA Sat Sep 9 12:51:28 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1099970-1104970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1149970-1154970 to database[32;1mInfo [0m:Lattice Sieving: Found 29242 relations in '/tmp/c105/c105.upload/c105.sieving.1094970-1099970.sfc5skke.gz', total is now 197264/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1094970-1099970 as ok (5.7% => ETA Sat Sep 9 14:11:38 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1104970-1109970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1154970-1159970 to database[32;1mInfo [0m:Lattice Sieving: Found 30660 relations in '/tmp/c105/c105.upload/c105.sieving.1089970-1094970.tf4_cvgs.gz', total is now 227924/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1089970-1094970 as ok (6.5% => ETA Sat Sep 9 12:54:16 2017)[32;1mInfo [0m:Lattice Sieving: Found 26903 relations in '/tmp/c105/c105.upload/c105.sieving.1104970-1109970.sb2ie1s8.gz', total is now 254827/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1104970-1109970 as ok (7.3% => ETA Sat Sep 9 13:51:09 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1109970-1114970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1159970-1164970 to database[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1114970-1119970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1164970-1169970 to database[32;1mInfo [0m:Lattice Sieving: Found 32995 relations in '/tmp/c105/c105.upload/c105.sieving.1099970-1104970.gtpj88v8.gz', total is now 287822/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1099970-1104970 as ok (8.3% => ETA Sat Sep 9 13:00:23 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1119970-1124970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1169970-1174970 to database[32;1mInfo [0m:Lattice Sieving: Found 30607 relations in '/tmp/c105/c105.upload/c105.sieving.1109970-1114970.o0pmpsbu.gz', total is now 318429/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1109970-1114970 as ok (9.1% => ETA Sat Sep 9 13:34:10 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1124970-1129970 to client localhost[32;1mInfo [0m:Lattice Sieving: Found 27715 relations in '/tmp/c105/c105.upload/c105.sieving.1114970-1119970.irs8wjb9.gz', total is now 346144/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1114970-1119970 as ok (9.9% => ETA Sat Sep 9 12:52:54 2017)[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1174970-1179970 to database[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1129970-1134970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1179970-1184970 to database[32;1mInfo [0m:Lattice Sieving: Found 28645 relations in '/tmp/c105/c105.upload/c105.sieving.1119970-1124970.ps3e_jn4.gz', total is now 374789/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1119970-1124970 as ok (10.8% => ETA Sat Sep 9 13:29:55 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1134970-1139970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1184970-1189970 to database[32;1mInfo [0m:Lattice Sieving: Found 31931 relations in '/tmp/c105/c105.upload/c105.sieving.1124970-1129970.92aegjcu.gz', total is now 406720/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1124970-1129970 as ok (11.7% => ETA Sat Sep 9 12:56:57 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1139970-1144970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1189970-1194970 to database[32;1mInfo [0m:Lattice Sieving: Found 29498 relations in '/tmp/c105/c105.upload/c105.sieving.1129970-1134970.o4_8yulo.gz', total is now 436218/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1129970-1134970 as ok (12.5% => ETA Sat Sep 9 13:22:11 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1144970-1149970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1194970-1199970 to database[32;1mInfo [0m:Lattice Sieving: Found 30491 relations in '/tmp/c105/c105.upload/c105.sieving.1134970-1139970.uofjv9uu.gz', total is now 466709/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1134970-1139970 as ok (13.4% => ETA Sat Sep 9 12:58:16 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1149970-1154970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1199970-1204970 to database[32;1mInfo [0m:Lattice Sieving: Found 28041 relations in '/tmp/c105/c105.upload/c105.sieving.1139970-1144970.4ypkzpbn.gz', total is now 494750/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1139970-1144970 as ok (14.2% => ETA Sat Sep 9 13:16:01 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1154970-1159970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1204970-1209970 to database[32;1mInfo [0m:Lattice Sieving: Found 30870 relations in '/tmp/c105/c105.upload/c105.sieving.1144970-1149970.h7yxpvcx.gz', total is now 525620/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1144970-1149970 as ok (15.1% => ETA Sat Sep 9 13:01:12 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1159970-1164970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1209970-1214970 to database[32;1mInfo [0m:Lattice Sieving: Found 26849 relations in '/tmp/c105/c105.upload/c105.sieving.1149970-1154970.mp8xj6im.gz', total is now 552469/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1149970-1154970 as ok (15.9% => ETA Sat Sep 9 13:10:19 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1164970-1169970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1214970-1219970 to database[32;1mInfo [0m:Lattice Sieving: Found 28779 relations in '/tmp/c105/c105.upload/c105.sieving.1154970-1159970.5up80lts.gz', total is now 581248/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1154970-1159970 as ok (16.7% => ETA Sat Sep 9 13:02:16 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1169970-1174970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1219970-1224970 to database[32;1mInfo [0m:Lattice Sieving: Found 31426 relations in '/tmp/c105/c105.upload/c105.sieving.1159970-1164970.6dksz9am.gz', total is now 612674/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1159970-1164970 as ok (17.6% => ETA Sat Sep 9 13:10:46 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1174970-1179970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1224970-1229970 to database[32;1mInfo [0m:Lattice Sieving: Found 30069 relations in '/tmp/c105/c105.upload/c105.sieving.1164970-1169970.tjcywca8.gz', total is now 642743/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1164970-1169970 as ok (18.4% => ETA Sat Sep 9 13:00:36 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1179970-1184970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1229970-1234970 to database[32;1mInfo [0m:Lattice Sieving: Found 26746 relations in '/tmp/c105/c105.upload/c105.sieving.1169970-1174970.y2wcek3j.gz', total is now 669489/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1169970-1174970 as ok (19.2% => ETA Sat Sep 9 13:06:55 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1184970-1189970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1234970-1239970 to database[32;1mInfo [0m:Lattice Sieving: Found 27759 relations in '/tmp/c105/c105.upload/c105.sieving.1174970-1179970.qz0bnbqc.gz', total is now 697248/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1174970-1179970 as ok (20.0% => ETA Sat Sep 9 13:00:30 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1189970-1194970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1239970-1244970 to database[32;1mInfo [0m:Lattice Sieving: Found 30155 relations in '/tmp/c105/c105.upload/c105.sieving.1179970-1184970.jfwuss63.gz', total is now 727403/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1179970-1184970 as ok (20.9% => ETA Sat Sep 9 13:07:59 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1194970-1199970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1244970-1249970 to database[32;1mInfo [0m:Lattice Sieving: Found 29752 relations in '/tmp/c105/c105.upload/c105.sieving.1184970-1189970._6gkyoqs.gz', total is now 757155/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1184970-1189970 as ok (21.7% => ETA Sat Sep 9 13:00:01 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1199970-1204970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1249970-1254970 to database[32;1mInfo [0m:Lattice Sieving: Found 29102 relations in '/tmp/c105/c105.upload/c105.sieving.1189970-1194970.n5yagb_a.gz', total is now 786257/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1189970-1194970 as ok (22.6% => ETA Sat Sep 9 13:07:24 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1204970-1209970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1254970-1259970 to database[32;1mInfo [0m:Lattice Sieving: Found 26390 relations in '/tmp/c105/c105.upload/c105.sieving.1194970-1199970.sdw5xv35.gz', total is now 812647/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1194970-1199970 as ok (23.3% => ETA Sat Sep 9 12:59:09 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1209970-1214970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1259970-1264970 to database[32;1mInfo [0m:Lattice Sieving: Found 23523 relations in '/tmp/c105/c105.upload/c105.sieving.1199970-1204970.knoob91g.gz', total is now 836170/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1199970-1204970 as ok (24.0% => ETA Sat Sep 9 13:05:24 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1214970-1219970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1264970-1269970 to database[32;1mInfo [0m:Lattice Sieving: Found 27148 relations in '/tmp/c105/c105.upload/c105.sieving.1204970-1209970.igqkcapj.gz', total is now 863318/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1204970-1209970 as ok (24.8% => ETA Sat Sep 9 13:01:33 2017)[32;1mInfo [0m:Lattice Sieving: Found 29811 relations in '/tmp/c105/c105.upload/c105.sieving.1209970-1214970.34v4k9rb.gz', total is now 893129/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1209970-1214970 as ok (25.6% => ETA Sat Sep 9 13:06:07 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1219970-1224970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1269970-1274970 to database[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1224970-1229970 to client localhost[32;1mInfo [0m:Lattice Sieving: Found 28420 relations in '/tmp/c105/c105.upload/c105.sieving.1214970-1219970.vsbqdr9d.gz', total is now 921549/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1214970-1219970 as ok (26.4% => ETA Sat Sep 9 13:00:30 2017)[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1274970-1279970 to database[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1229970-1234970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1279970-1284970 to database[32;1mInfo [0m:Lattice Sieving: Found 23763 relations in '/tmp/c105/c105.upload/c105.sieving.1219970-1224970.dhtb__tj.gz', total is now 945312/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1219970-1224970 as ok (27.1% => ETA Sat Sep 9 13:03:05 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1234970-1239970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1284970-1289970 to database[32;1mInfo [0m:Lattice Sieving: Found 27594 relations in '/tmp/c105/c105.upload/c105.sieving.1224970-1229970.rfszhsov.gz', total is now 972906/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1224970-1229970 as ok (27.9% => ETA Sat Sep 9 13:02:58 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1239970-1244970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1289970-1294970 to database[32;1mInfo [0m:Lattice Sieving: Found 27234 relations in '/tmp/c105/c105.upload/c105.sieving.1229970-1234970.vggf_fux.gz', total is now 1000140/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1229970-1234970 as ok (28.7% => ETA Sat Sep 9 13:02:46 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1244970-1249970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1294970-1299970 to database[32;1mInfo [0m:Lattice Sieving: Found 27877 relations in '/tmp/c105/c105.upload/c105.sieving.1234970-1239970.6r2xpfjk.gz', total is now 1028017/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1234970-1239970 as ok (29.5% => ETA Sat Sep 9 13:04:54 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1249970-1254970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1299970-1304970 to database[32;1mInfo [0m:Lattice Sieving: Found 25501 relations in '/tmp/c105/c105.upload/c105.sieving.1239970-1244970.pqcn194l.gz', total is now 1053518/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1239970-1244970 as ok (30.2% => ETA Sat Sep 9 13:03:15 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1254970-1259970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1304970-1309970 to database[32;1mInfo [0m:Lattice Sieving: Found 28702 relations in '/tmp/c105/c105.upload/c105.sieving.1244970-1249970.7n1vbj3e.gz', total is now 1082220/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1244970-1249970 as ok (31.0% => ETA Sat Sep 9 13:06:28 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1259970-1264970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1309970-1314970 to database[32;1mInfo [0m:Lattice Sieving: Found 24756 relations in '/tmp/c105/c105.upload/c105.sieving.1249970-1254970.os344nk2.gz', total is now 1106976/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1249970-1254970 as ok (31.8% => ETA Sat Sep 9 13:01:41 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1264970-1269970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1314970-1319970 to database[32;1mInfo [0m:Lattice Sieving: Found 27647 relations in '/tmp/c105/c105.upload/c105.sieving.1254970-1259970.6855bqqy.gz', total is now 1134623/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1254970-1259970 as ok (32.6% => ETA Sat Sep 9 13:07:56 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1269970-1274970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1319970-1324970 to database[32;1mInfo [0m:Lattice Sieving: Found 25636 relations in '/tmp/c105/c105.upload/c105.sieving.1259970-1264970.dobnnvit.gz', total is now 1160259/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1259970-1264970 as ok (33.3% => ETA Sat Sep 9 13:01:06 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1274970-1279970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1324970-1329970 to database[32;1mInfo [0m:Lattice Sieving: Found 28709 relations in '/tmp/c105/c105.upload/c105.sieving.1264970-1269970.dxqas925.gz', total is now 1188968/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1264970-1269970 as ok (34.1% => ETA Sat Sep 9 13:09:21 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1279970-1284970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1329970-1334970 to database[32;1mInfo [0m:Lattice Sieving: Found 26576 relations in '/tmp/c105/c105.upload/c105.sieving.1269970-1274970.69m8abpi.gz', total is now 1215544/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1269970-1274970 as ok (34.9% => ETA Sat Sep 9 13:00:35 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1284970-1289970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1334970-1339970 to database[32;1mInfo [0m:Lattice Sieving: Found 28355 relations in '/tmp/c105/c105.upload/c105.sieving.1274970-1279970.jppuh8ht.gz', total is now 1243899/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1274970-1279970 as ok (35.7% => ETA Sat Sep 9 13:10:11 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1289970-1294970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1339970-1344970 to database[32;1mInfo [0m:Lattice Sieving: Found 26537 relations in '/tmp/c105/c105.upload/c105.sieving.1279970-1284970.7n8sfgtx.gz', total is now 1270436/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1279970-1284970 as ok (36.4% => ETA Sat Sep 9 13:00:16 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1294970-1299970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1344970-1349970 to database[32;1mInfo [0m:Lattice Sieving: Found 25634 relations in '/tmp/c105/c105.upload/c105.sieving.1289970-1294970.0p0ypbtz.gz', total is now 1296070/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1289970-1294970 as ok (37.2% => ETA Sat Sep 9 13:11:45 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1299970-1304970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1349970-1354970 to database[32;1mInfo [0m:Lattice Sieving: Found 28510 relations in '/tmp/c105/c105.upload/c105.sieving.1284970-1289970.zug5wtok.gz', total is now 1324580/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1284970-1289970 as ok (38.0% => ETA Sat Sep 9 12:59:46 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1304970-1309970 to client localhost+2[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1309970-1314970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1354970-1359970 to database[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1359970-1364970 to database[32;1mInfo [0m:Lattice Sieving: Found 27163 relations in '/tmp/c105/c105.upload/c105.sieving.1294970-1299970.r78gm18u.gz', total is now 1351743/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1294970-1299970 as ok (38.8% => ETA Sat Sep 9 13:11:23 2017)[32;1mInfo [0m:Lattice Sieving: Found 27044 relations in '/tmp/c105/c105.upload/c105.sieving.1299970-1304970.cjnxygzb.gz', total is now 1378787/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1299970-1304970 as ok (39.6% => ETA Sat Sep 9 13:00:16 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1314970-1319970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1364970-1369970 to database[32;1mInfo [0m:Lattice Sieving: Found 25250 relations in '/tmp/c105/c105.upload/c105.sieving.1309970-1314970.2l4casga.gz', total is now 1404037/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1309970-1314970 as ok (40.3% => ETA Sat Sep 9 13:10:31 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1319970-1324970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1369970-1374970 to database[32;1mInfo [0m:Lattice Sieving: Found 26045 relations in '/tmp/c105/c105.upload/c105.sieving.1304970-1309970.affxx3hp.gz', total is now 1430082/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1304970-1309970 as ok (41.0% => ETA Sat Sep 9 13:01:00 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1324970-1329970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1374970-1379970 to database[32;1mInfo [0m:Lattice Sieving: Found 26392 relations in '/tmp/c105/c105.upload/c105.sieving.1314970-1319970.ua9j84ig.gz', total is now 1456474/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1314970-1319970 as ok (41.8% => ETA Sat Sep 9 13:10:28 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1329970-1334970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1379970-1384970 to database[32;1mInfo [0m:Lattice Sieving: Found 30101 relations in '/tmp/c105/c105.upload/c105.sieving.1319970-1324970.2pf0jm7u.gz', total is now 1486575/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1319970-1324970 as ok (42.7% => ETA Sat Sep 9 13:02:57 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1334970-1339970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1384970-1389970 to database[32;1mInfo [0m:Lattice Sieving: Found 29162 relations in '/tmp/c105/c105.upload/c105.sieving.1324970-1329970.687k6wus.gz', total is now 1515737/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1324970-1329970 as ok (43.5% => ETA Sat Sep 9 13:10:18 2017)[32;1mInfo [0m:Lattice Sieving: Found 24198 relations in '/tmp/c105/c105.upload/c105.sieving.1329970-1334970.rvxv8dz_.gz', total is now 1539935/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1329970-1334970 as ok (44.2% => ETA Sat Sep 9 13:01:34 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1339970-1344970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1389970-1394970 to database[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1344970-1349970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1394970-1399970 to database[32;1mInfo [0m:Lattice Sieving: Found 26460 relations in '/tmp/c105/c105.upload/c105.sieving.1339970-1344970.fzr4ihah.gz', total is now 1566395/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1339970-1344970 as ok (44.9% => ETA Sat Sep 9 13:11:20 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1349970-1354970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1399970-1404970 to database[32;1mInfo [0m:Lattice Sieving: Found 28274 relations in '/tmp/c105/c105.upload/c105.sieving.1334970-1339970.nq_6xgzs.gz', total is now 1594669/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1334970-1339970 as ok (45.8% => ETA Sat Sep 9 13:02:39 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1354970-1359970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1404970-1409970 to database[32;1mInfo [0m:Lattice Sieving: Found 24737 relations in '/tmp/c105/c105.upload/c105.sieving.1344970-1349970.2a2mkfs7.gz', total is now 1619406/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1344970-1349970 as ok (46.5% => ETA Sat Sep 9 13:10:24 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1359970-1364970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1409970-1414970 to database[32;1mInfo [0m:Lattice Sieving: Found 27549 relations in '/tmp/c105/c105.upload/c105.sieving.1349970-1354970.uwfi5w3m.gz', total is now 1646955/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1349970-1354970 as ok (47.3% => ETA Sat Sep 9 13:04:00 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1364970-1369970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1414970-1419970 to database[32;1mInfo [0m:Lattice Sieving: Found 27777 relations in '/tmp/c105/c105.upload/c105.sieving.1354970-1359970.mgm2pjcu.gz', total is now 1674732/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1354970-1359970 as ok (48.0% => ETA Sat Sep 9 13:10:45 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1369970-1374970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1419970-1424970 to database[32;1mInfo [0m:Lattice Sieving: Found 27915 relations in '/tmp/c105/c105.upload/c105.sieving.1359970-1364970.x8k4bwb0.gz', total is now 1702647/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1359970-1364970 as ok (48.9% => ETA Sat Sep 9 13:04:26 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1374970-1379970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1424970-1429970 to database[32;1mInfo [0m:Lattice Sieving: Found 23459 relations in '/tmp/c105/c105.upload/c105.sieving.1364970-1369970.lj9t6uww.gz', total is now 1726106/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1364970-1369970 as ok (49.5% => ETA Sat Sep 9 13:09:20 2017)[32;1mInfo [0m:Lattice Sieving: Found 26797 relations in '/tmp/c105/c105.upload/c105.sieving.1369970-1374970.brbky4u8.gz', total is now 1752903/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1369970-1374970 as ok (50.3% => ETA Sat Sep 9 13:05:53 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1379970-1384970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1429970-1434970 to database[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1384970-1389970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1434970-1439970 to database[32;1mInfo [0m:Lattice Sieving: Found 30021 relations in '/tmp/c105/c105.upload/c105.sieving.1374970-1379970.3lh7vces.gz', total is now 1782924/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1374970-1379970 as ok (51.2% => ETA Sat Sep 9 13:10:54 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1389970-1394970 to client localhost[32;1mInfo [0m:Lattice Sieving: Found 25176 relations in '/tmp/c105/c105.upload/c105.sieving.1379970-1384970.do0nnuyh.gz', total is now 1808100/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1379970-1384970 as ok (51.9% => ETA Sat Sep 9 13:04:52 2017)[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1439970-1444970 to database[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1394970-1399970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Found 27846 relations in '/tmp/c105/c105.upload/c105.sieving.1384970-1389970.j_nhwi2i.gz', total is now 1835946/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1384970-1389970 as ok (52.7% => ETA Sat Sep 9 13:12:14 2017)[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1444970-1449970 to database[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1399970-1404970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1449970-1454970 to database[32;1mInfo [0m:Lattice Sieving: Found 25758 relations in '/tmp/c105/c105.upload/c105.sieving.1389970-1394970.ym98gs7d.gz', total is now 1861704/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1389970-1394970 as ok (53.4% => ETA Sat Sep 9 13:04:44 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1404970-1409970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1454970-1459970 to database[32;1mInfo [0m:Lattice Sieving: Found 24439 relations in '/tmp/c105/c105.upload/c105.sieving.1399970-1404970.buhblptg.gz', total is now 1886143/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1399970-1404970 as ok (54.1% => ETA Sat Sep 9 13:12:31 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1409970-1414970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1459970-1464970 to database[32;1mInfo [0m:Lattice Sieving: Found 28202 relations in '/tmp/c105/c105.upload/c105.sieving.1394970-1399970.ghj3djtx.gz', total is now 1914345/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1394970-1399970 as ok (54.9% => ETA Sat Sep 9 13:05:59 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1414970-1419970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1464970-1469970 to database[32;1mInfo [0m:Lattice Sieving: Found 27396 relations in '/tmp/c105/c105.upload/c105.sieving.1404970-1409970.s1s_o4js.gz', total is now 1941741/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1404970-1409970 as ok (55.7% => ETA Sat Sep 9 13:12:19 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1419970-1424970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1469970-1474970 to database[32;1mInfo [0m:Lattice Sieving: Found 29414 relations in '/tmp/c105/c105.upload/c105.sieving.1409970-1414970.cva7m12c.gz', total is now 1971155/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1409970-1414970 as ok (56.6% => ETA Sat Sep 9 13:07:19 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1424970-1429970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1474970-1479970 to database[32;1mInfo [0m:Lattice Sieving: Found 24644 relations in '/tmp/c105/c105.upload/c105.sieving.1414970-1419970.y1sc3v4c.gz', total is now 1995799/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1414970-1419970 as ok (57.3% => ETA Sat Sep 9 13:11:22 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1429970-1434970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1479970-1484970 to database[32;1mInfo [0m:Lattice Sieving: Found 26391 relations in '/tmp/c105/c105.upload/c105.sieving.1419970-1424970.58gfhtsy.gz', total is now 2022190/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1419970-1424970 as ok (58.0% => ETA Sat Sep 9 13:08:12 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1434970-1439970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1484970-1489970 to database[32;1mInfo [0m:Lattice Sieving: Found 28064 relations in '/tmp/c105/c105.upload/c105.sieving.1424970-1429970.1hz0r19z.gz', total is now 2050254/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1424970-1429970 as ok (58.8% => ETA Sat Sep 9 13:12:16 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1439970-1444970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1489970-1494970 to database[32;1mInfo [0m:Lattice Sieving: Found 28027 relations in '/tmp/c105/c105.upload/c105.sieving.1429970-1434970.qd65a9le.gz', total is now 2078281/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1429970-1434970 as ok (59.6% => ETA Sat Sep 9 13:08:34 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1444970-1449970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1494970-1499970 to database[32;1mInfo [0m:Lattice Sieving: Found 26618 relations in '/tmp/c105/c105.upload/c105.sieving.1434970-1439970.unahy6ye.gz', total is now 2104899/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1434970-1439970 as ok (60.4% => ETA Sat Sep 9 13:12:13 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1449970-1454970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1499970-1504970 to database[32;1mInfo [0m:Lattice Sieving: Found 26008 relations in '/tmp/c105/c105.upload/c105.sieving.1439970-1444970.yfxnsyk4.gz', total is now 2130907/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1439970-1444970 as ok (61.1% => ETA Sat Sep 9 13:08:47 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1454970-1459970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1504970-1509970 to database[32;1mInfo [0m:Lattice Sieving: Found 25189 relations in '/tmp/c105/c105.upload/c105.sieving.1444970-1449970.utega9td.gz', total is now 2156096/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1444970-1449970 as ok (61.9% => ETA Sat Sep 9 13:12:23 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1459970-1464970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1509970-1514970 to database[32;1mInfo [0m:Lattice Sieving: Found 25670 relations in '/tmp/c105/c105.upload/c105.sieving.1449970-1454970.tvhm83eg.gz', total is now 2181766/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1449970-1454970 as ok (62.6% => ETA Sat Sep 9 13:09:04 2017)[32;1mInfo [0m:Lattice Sieving: Found 23565 relations in '/tmp/c105/c105.upload/c105.sieving.1454970-1459970.howhql5w.gz', total is now 2205331/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1454970-1459970 as ok (63.3% => ETA Sat Sep 9 13:12:07 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1464970-1469970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1514970-1519970 to database[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1469970-1474970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1519970-1524970 to database[32;1mInfo [0m:Lattice Sieving: Found 28712 relations in '/tmp/c105/c105.upload/c105.sieving.1459970-1464970.anr0_dgf.gz', total is now 2234043/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1459970-1464970 as ok (64.1% => ETA Sat Sep 9 13:10:51 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1474970-1479970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1524970-1529970 to database[32;1mInfo [0m:Lattice Sieving: Found 27622 relations in '/tmp/c105/c105.upload/c105.sieving.1464970-1469970.nqsr0udc.gz', total is now 2261665/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1464970-1469970 as ok (64.9% => ETA Sat Sep 9 13:12:16 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1479970-1484970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Found 27517 relations in '/tmp/c105/c105.upload/c105.sieving.1469970-1474970.kpamcmtg.gz', total is now 2289182/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1469970-1474970 as ok (65.7% => ETA Sat Sep 9 13:11:13 2017)[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1529970-1534970 to database[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1484970-1489970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1534970-1539970 to database[32;1mInfo [0m:Lattice Sieving: Found 24682 relations in '/tmp/c105/c105.upload/c105.sieving.1474970-1479970.92k5ojg4.gz', total is now 2313864/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1474970-1479970 as ok (66.4% => ETA Sat Sep 9 13:11:58 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1489970-1494970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1539970-1544970 to database[32;1mInfo [0m:Lattice Sieving: Found 27345 relations in '/tmp/c105/c105.upload/c105.sieving.1479970-1484970.2f14bs4q.gz', total is now 2341209/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1479970-1484970 as ok (67.2% => ETA Sat Sep 9 13:12:10 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1494970-1499970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1544970-1549970 to database[32;1mInfo [0m:Lattice Sieving: Found 25056 relations in '/tmp/c105/c105.upload/c105.sieving.1484970-1489970.m3aycry8.gz', total is now 2366265/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1484970-1489970 as ok (67.9% => ETA Sat Sep 9 13:11:49 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1499970-1504970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1549970-1554970 to database[32;1mInfo [0m:Lattice Sieving: Found 28251 relations in '/tmp/c105/c105.upload/c105.sieving.1489970-1494970.pbgfbzrb.gz', total is now 2394516/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1489970-1494970 as ok (68.7% => ETA Sat Sep 9 13:13:15 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1504970-1509970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1554970-1559970 to database[32;1mInfo [0m:Lattice Sieving: Found 26062 relations in '/tmp/c105/c105.upload/c105.sieving.1494970-1499970.ps9nsxq4.gz', total is now 2420578/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1494970-1499970 as ok (69.4% => ETA Sat Sep 9 13:11:43 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1509970-1514970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1559970-1564970 to database[32;1mInfo [0m:Lattice Sieving: Found 29116 relations in '/tmp/c105/c105.upload/c105.sieving.1499970-1504970.hmua2myb.gz', total is now 2449694/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1499970-1504970 as ok (70.3% => ETA Sat Sep 9 13:14:20 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1514970-1519970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1564970-1569970 to database[32;1mInfo [0m:Lattice Sieving: Found 27794 relations in '/tmp/c105/c105.upload/c105.sieving.1504970-1509970._l9vxo1x.gz', total is now 2477488/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1504970-1509970 as ok (71.1% => ETA Sat Sep 9 13:11:51 2017)[32;1mInfo [0m:Lattice Sieving: Found 29469 relations in '/tmp/c105/c105.upload/c105.sieving.1509970-1514970.fzxw6dqy.gz', total is now 2506957/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1509970-1514970 as ok (71.9% => ETA Sat Sep 9 13:14:53 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1519970-1524970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1569970-1574970 to database[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1524970-1529970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1574970-1579970 to database[32;1mInfo [0m:Lattice Sieving: Found 25892 relations in '/tmp/c105/c105.upload/c105.sieving.1514970-1519970.dovedohk.gz', total is now 2532849/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1514970-1519970 as ok (72.7% => ETA Sat Sep 9 13:11:34 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1529970-1534970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1579970-1584970 to database[32;1mInfo [0m:Lattice Sieving: Found 22692 relations in '/tmp/c105/c105.upload/c105.sieving.1519970-1524970.piekyrnd.gz', total is now 2555541/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1519970-1524970 as ok (73.3% => ETA Sat Sep 9 13:14:40 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1534970-1539970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1584970-1589970 to database[32;1mInfo [0m:Lattice Sieving: Found 28892 relations in '/tmp/c105/c105.upload/c105.sieving.1524970-1529970.oicb2q2_.gz', total is now 2584433/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1524970-1529970 as ok (74.1% => ETA Sat Sep 9 13:13:23 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1539970-1544970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1589970-1594970 to database[32;1mInfo [0m:Lattice Sieving: Found 24842 relations in '/tmp/c105/c105.upload/c105.sieving.1529970-1534970.pqudws37.gz', total is now 2609275/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1529970-1534970 as ok (74.9% => ETA Sat Sep 9 13:13:59 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1544970-1549970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1594970-1599970 to database[32;1mInfo [0m:Lattice Sieving: Found 25927 relations in '/tmp/c105/c105.upload/c105.sieving.1534970-1539970.bq8x9xyl.gz', total is now 2635202/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1534970-1539970 as ok (75.6% => ETA Sat Sep 9 13:13:54 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1549970-1554970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1599970-1604970 to database[32;1mInfo [0m:Lattice Sieving: Found 24567 relations in '/tmp/c105/c105.upload/c105.sieving.1539970-1544970.h8j5xcmz.gz', total is now 2659769/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1539970-1544970 as ok (76.3% => ETA Sat Sep 9 13:14:06 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1554970-1559970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1604970-1609970 to database[32;1mInfo [0m:Lattice Sieving: Found 24067 relations in '/tmp/c105/c105.upload/c105.sieving.1544970-1549970.q6r3ue34.gz', total is now 2683836/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1544970-1549970 as ok (77.0% => ETA Sat Sep 9 13:14:23 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1559970-1564970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1609970-1614970 to database[32;1mInfo [0m:Lattice Sieving: Found 23838 relations in '/tmp/c105/c105.upload/c105.sieving.1549970-1554970.u0trzb7t.gz', total is now 2707674/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1549970-1554970 as ok (77.7% => ETA Sat Sep 9 13:14:30 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1564970-1569970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1614970-1619970 to database[32;1mInfo [0m:Lattice Sieving: Found 28248 relations in '/tmp/c105/c105.upload/c105.sieving.1554970-1559970.jk_6qoc7.gz', total is now 2735922/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1554970-1559970 as ok (78.5% => ETA Sat Sep 9 13:15:44 2017)[32;1mInfo [0m:Lattice Sieving: Found 25848 relations in '/tmp/c105/c105.upload/c105.sieving.1559970-1564970.ljnca8ao.gz', total is now 2761770/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1559970-1564970 as ok (79.2% => ETA Sat Sep 9 13:14:26 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1569970-1574970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1619970-1624970 to database[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1574970-1579970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1624970-1629970 to database[32;1mInfo [0m:Lattice Sieving: Found 24611 relations in '/tmp/c105/c105.upload/c105.sieving.1564970-1569970.znroz47l.gz', total is now 2786381/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1564970-1569970 as ok (79.9% => ETA Sat Sep 9 13:15:49 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1579970-1584970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1629970-1634970 to database[32;1mInfo [0m:Lattice Sieving: Found 25010 relations in '/tmp/c105/c105.upload/c105.sieving.1569970-1574970.plruz5hn.gz', total is now 2811391/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1569970-1574970 as ok (80.7% => ETA Sat Sep 9 13:14:54 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1584970-1589970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1634970-1639970 to database[32;1mInfo [0m:Lattice Sieving: Found 24684 relations in '/tmp/c105/c105.upload/c105.sieving.1574970-1579970.m4z9loka.gz', total is now 2836075/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1574970-1579970 as ok (81.4% => ETA Sat Sep 9 13:16:14 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1589970-1594970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1639970-1644970 to database[32;1mInfo [0m:Lattice Sieving: Found 24836 relations in '/tmp/c105/c105.upload/c105.sieving.1579970-1584970.jf2ns_8_.gz', total is now 2860911/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1579970-1584970 as ok (82.1% => ETA Sat Sep 9 13:15:25 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1594970-1599970 to client localhost[32;1mInfo [0m:Lattice Sieving: Found 24118 relations in '/tmp/c105/c105.upload/c105.sieving.1584970-1589970.mhcxwffh.gz', total is now 2885029/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1584970-1589970 as ok (82.8% => ETA Sat Sep 9 13:16:25 2017)[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1644970-1649970 to database[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1599970-1604970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1649970-1654970 to database[32;1mInfo [0m:Lattice Sieving: Found 25931 relations in '/tmp/c105/c105.upload/c105.sieving.1589970-1594970.unlwfag1.gz', total is now 2910960/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1589970-1594970 as ok (83.5% => ETA Sat Sep 9 13:16:11 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1604970-1609970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1654970-1659970 to database[32;1mInfo [0m:Lattice Sieving: Found 23983 relations in '/tmp/c105/c105.upload/c105.sieving.1594970-1599970.pfao7x02.gz', total is now 2934943/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1594970-1599970 as ok (84.2% => ETA Sat Sep 9 13:16:29 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1609970-1614970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1659970-1664970 to database[32;1mInfo [0m:Lattice Sieving: Found 28494 relations in '/tmp/c105/c105.upload/c105.sieving.1599970-1604970.b0gvyriw.gz', total is now 2963437/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1599970-1604970 as ok (85.0% => ETA Sat Sep 9 13:17:36 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1614970-1619970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1664970-1669970 to database[32;1mInfo [0m:Lattice Sieving: Found 24142 relations in '/tmp/c105/c105.upload/c105.sieving.1604970-1609970.ofkuh0m4.gz', total is now 2987579/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1604970-1609970 as ok (85.7% => ETA Sat Sep 9 13:15:58 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1619970-1624970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1669970-1674970 to database[32;1mInfo [0m:Lattice Sieving: Found 25356 relations in '/tmp/c105/c105.upload/c105.sieving.1609970-1614970.0kyddwr_.gz', total is now 3012935/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1609970-1614970 as ok (86.4% => ETA Sat Sep 9 13:18:08 2017)[32;1mInfo [0m:Lattice Sieving: Found 26702 relations in '/tmp/c105/c105.upload/c105.sieving.1614970-1619970.m1fku3hi.gz', total is now 3039637/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1614970-1619970 as ok (87.2% => ETA Sat Sep 9 13:16:36 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1624970-1629970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1674970-1679970 to database[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1629970-1634970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1679970-1684970 to database[32;1mInfo [0m:Lattice Sieving: Found 25331 relations in '/tmp/c105/c105.upload/c105.sieving.1619970-1624970.trco2844.gz', total is now 3064968/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1619970-1624970 as ok (87.9% => ETA Sat Sep 9 13:18:16 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1634970-1639970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1684970-1689970 to database[32;1mInfo [0m:Lattice Sieving: Found 24557 relations in '/tmp/c105/c105.upload/c105.sieving.1624970-1629970.vcus3c71.gz', total is now 3089525/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1624970-1629970 as ok (88.6% => ETA Sat Sep 9 13:16:53 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1639970-1644970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1689970-1694970 to database[32;1mInfo [0m:Lattice Sieving: Found 27454 relations in '/tmp/c105/c105.upload/c105.sieving.1629970-1634970.igeoltdo.gz', total is now 3116979/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1629970-1634970 as ok (89.4% => ETA Sat Sep 9 13:19:05 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1644970-1649970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1694970-1699970 to database[32;1mInfo [0m:Lattice Sieving: Found 21640 relations in '/tmp/c105/c105.upload/c105.sieving.1634970-1639970.bogezw75.gz', total is now 3138619/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1634970-1639970 as ok (90.0% => ETA Sat Sep 9 13:16:10 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1649970-1654970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1699970-1704970 to database[32;1mInfo [0m:Lattice Sieving: Found 24376 relations in '/tmp/c105/c105.upload/c105.sieving.1639970-1644970.t3lrpu2o.gz', total is now 3162995/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1639970-1644970 as ok (90.7% => ETA Sat Sep 9 13:19:59 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1654970-1659970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1704970-1709970 to database[32;1mInfo [0m:Lattice Sieving: Found 24822 relations in '/tmp/c105/c105.upload/c105.sieving.1644970-1649970.606gcgc9.gz', total is now 3187817/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1644970-1649970 as ok (91.5% => ETA Sat Sep 9 13:16:43 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1659970-1664970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1709970-1714970 to database[32;1mInfo [0m:Lattice Sieving: Found 25099 relations in '/tmp/c105/c105.upload/c105.sieving.1649970-1654970.6yoaalz9.gz', total is now 3212916/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1649970-1654970 as ok (92.2% => ETA Sat Sep 9 13:20:17 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1664970-1669970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1714970-1719970 to database[32;1mInfo [0m:Lattice Sieving: Found 23536 relations in '/tmp/c105/c105.upload/c105.sieving.1654970-1659970.xwto4e4k.gz', total is now 3236452/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1654970-1659970 as ok (92.9% => ETA Sat Sep 9 13:16:49 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1669970-1674970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1719970-1724970 to database[32;1mInfo [0m:Lattice Sieving: Found 25725 relations in '/tmp/c105/c105.upload/c105.sieving.1659970-1664970.77ziz_6n.gz', total is now 3262177/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1659970-1664970 as ok (93.6% => ETA Sat Sep 9 13:21:01 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1674970-1679970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1724970-1729970 to database[32;1mInfo [0m:Lattice Sieving: Found 28057 relations in '/tmp/c105/c105.upload/c105.sieving.1664970-1669970.9yp7k3ec.gz', total is now 3290234/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1664970-1669970 as ok (94.4% => ETA Sat Sep 9 13:17:44 2017)[32;1mInfo [0m:Lattice Sieving: Found 24442 relations in '/tmp/c105/c105.upload/c105.sieving.1669970-1674970.xbc8hce8.gz', total is now 3314676/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1669970-1674970 as ok (95.1% => ETA Sat Sep 9 13:20:52 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1679970-1684970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1729970-1734970 to database[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1684970-1689970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1734970-1739970 to database[32;1mInfo [0m:Lattice Sieving: Found 27870 relations in '/tmp/c105/c105.upload/c105.sieving.1674970-1679970.e31p2w08.gz', total is now 3342546/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1674970-1679970 as ok (95.9% => ETA Sat Sep 9 13:18:49 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1689970-1694970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Found 24571 relations in '/tmp/c105/c105.upload/c105.sieving.1679970-1684970.v9dkxl50.gz', total is now 3367117/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1679970-1684970 as ok (96.6% => ETA Sat Sep 9 13:20:36 2017)[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1739970-1744970 to database[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1694970-1699970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1744970-1749970 to database[32;1mInfo [0m:Lattice Sieving: Found 24895 relations in '/tmp/c105/c105.upload/c105.sieving.1684970-1689970.ltkexb1m.gz', total is now 3392012/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1684970-1689970 as ok (97.3% => ETA Sat Sep 9 13:19:09 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1699970-1704970 to client localhost+2[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1749970-1754970 to database[32;1mInfo [0m:Lattice Sieving: Found 26980 relations in '/tmp/c105/c105.upload/c105.sieving.1689970-1694970.oethusq9.gz', total is now 3418992/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1689970-1694970 as ok (98.1% => ETA Sat Sep 9 13:21:14 2017)[32;1mInfo [0m:Lattice Sieving: Found 25989 relations in '/tmp/c105/c105.upload/c105.sieving.1694970-1699970.xehnak6w.gz', total is now 3444981/3485434[32;1mInfo [0m:Lattice Sieving: Marking workunit c105_sieving_1694970-1699970 as ok (98.8% => ETA Sat Sep 9 13:19:30 2017)[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_sieving_1704970-1709970 to client localhost[32;1mInfo [0m:Lattice Sieving: Adding workunit c105_sieving_1754970-1759970 to database[32;1mInfo [0m:HTTP server: 127.0.0.1 Sending workunit c105_si
- [Cado-nfs-discuss] Square Root Freeze, Anderson Felipe Jimenez Guevara, 09/07/2017
- Re: [Cado-nfs-discuss] Square Root Freeze, paul zimmermann, 09/08/2017
- Message not available
- [Cado-nfs-discuss] Square Root Freeze, Anderson Felipe Jimenez Guevara, 09/11/2017
- <Possible follow-up(s)>
- [Cado-nfs-discuss] Square Root Freeze, paul zimmermann, 09/11/2017
- Re: [Cado-nfs-discuss] Square Root Freeze, Anderson Felipe Jimenez Guevara, 09/11/2017
