cado-nfs - Re: [Cado-nfs-discuss] Cado-nfs 2.3.0 fails to merge
  • To: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] Cado-nfs 2.3.0 fails to merge
  • Date: Fri, 29 Sep 2017 06:16:53 +0000 (GMT)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=snae@unseen.is; spf=Pass smtp.mailfrom=snae@unseen.is; spf=None smtp.helo=postmaster@mt09.unseen.is
  • Dkim-filter: OpenDKIM Filter v2.9.2 mt09.unseen.is 84EED1029BA
  • Ironport-phdr: 9a23:tOwbVxwvy2L5rYHXCy+O+j09IxM/srCxBDY+r6Qd0u8QIJqq85mqBkHD//Il1AaPBtqLra8cw8Pt8IneGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2NBXupSi55DIVXxPxLk95J//+B5XJp8C2zPypvZLdZB9HiXy8Z6lzJVO4t1b/rM4T1JBkI6sZ1x3Sr3ZOPeVNljAgHk6agxupvpT4x5Vk6SkF4/8=
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Merge now works. Updated the parameters in
parameter/factors/params.c150
Tried re-running
Noticed snapshot needed to be updated (correct?):
tasks.filter.maxlevel
tasks.filter.target_density
After updating these two lines the merge session worked now it fails on the replay part:
Info:Filtering - Merging: Starting
Info:Filtering - Merging: Merged matrix has 6250575 rows and total weight 625057511 (100.0 entries per row on average)
Warning:Command: Process with PID 14597 finished with return code -6
Error:Filtering - Merging: Program run on server failed with exit code -6
Error:Filtering - Merging: Command line was: /home/computer/Desktop/cado-nfs/build/computer/filter/replay -purged /tmp/cado.qcwempoo/c150.purged.gz -his /tmp/cado.qcwempoo/c150.history.gz -index /tmp/cado.qcwempoo/c150.index.gz -out /tmp/cado.qcwempoo/c150.sparse.bin > /tmp/cado.qcwempoo/c150.replay.stdout.8 2> /tmp/cado.qcwempoo/c150.replay.stderr.8
Error:Filtering - Merging: Stderr output follows (stored in file /tmp/cado.qcwempoo/c150.replay.stderr.8):
b'antebuffer set to /home/computer/Desktop/cado-nfs/build/computer/utils/antebuffer\nfork: Cannot allocate memory\ncode BUG() : condition indexfile != NULL failed in writeIndex at /home/computer/Desktop/cado-nfs/filter/replay.c:560 -- Abort\n'
Traceback (most recent call last):
  File "./cado-nfs.py", line 122, in <module>
    factors = factorjob.run()
  File "./scripts/cadofactor/cadotask.py", line 5429, in run
    last_status, last_task = self.run_next_task()
  File "./scripts/cadofactor/cadotask.py", line 5504, in run_next_task
    return [task.run(), task.title]
  File "./scripts/cadofactor/cadotask.py", line 3904, in run
    raise Exception("Program failed")
Are there other things which need to be updated?
