Re: [Cado-nfs-discuss] Will hyperthreading result in faster or slower sieve times?
- To: paul zimmermann <Paul.Zimmermann@inria.fr>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] Will hyperthreading result in faster or slower sieve times?
- Date: Fri, 19 Jan 2018 06:13:15 -0500 (EST)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=rjd1212@cox.net; spf=Pass smtp.mailfrom=rjd1212@cox.net; spf=None smtp.helo=postmaster@eastrmfepo101.cox.net
- Importance: Medium
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Thanks for the quick reply, Paul,
OK - then, that's good news concerning the hyperthreading increasing the wall clock time & that there is no network bottleneck.
On each of the seven clients that are performing the sieving, all have 16GB of DDR4 3000 memory - while the server has 64GB of the same memory running 16 threads. ( 8 cores )
Best Regards,
RJD
> On January 19, 2018 at 5:44 AM paul zimmermann <Paul.Zimmermann@inria.fr> wrote:
> Robert,
> > Currently, I am factoring RSA C180, utilizing a 10GB network using eight machines
> > for a total of 72 threads.
> > Would eliminating the hyperthreading portion speed up the lattice sieving, in
> > addition to possibly tamping down any possible network bottleneck, or not?
> > Best Regards,
> > RJD
> my experience is that using hyperthreading helps to reduce the wall-clock time,
> assuming the las jobs do not exceed the available memory of each node.
> In the sieving phase there is no network bottleneck.
> Best regards,
> Paul Zimmermann
- [Cado-nfs-discuss] Will hyperthreading result in faster or slower sieve times?, ROBERT DUCHATEAU, 01/19/2018
- Re: [Cado-nfs-discuss] Will hyperthreading result in faster or slower sieve times?, paul zimmermann, 01/19/2018
- Message not available
- Re: [Cado-nfs-discuss] Will hyperthreading result in faster or slower sieve times?, ROBERT DUCHATEAU, 01/19/2018
