cado-nfs - Re: [Cado-nfs-discuss] unbearably slow factorization
  • To: Emmanuel Thomé <Emmanuel.Thome@inria.fr>
  • Cc: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] unbearably slow factorization
  • Date: Fri, 26 Jan 2018 17:31:41 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
On Fri, Jan 26, 2018 at 05:23:02PM +0100, Emmanuel Thomé wrote:
> On Fri, Jan 26, 2018 at 09:07:19AM -0700, mike@mikepage.us wrote:
> > Is this just an issue with suitability of the algorithm? Why is nfs such
> > a poor performer on this input?
> Because cado-nfs is an implementation of the number field sieve.
> The number field sieve is not always the algorithm you want to use to
> factor some given integer. The archetypal example is with "easy" integers
> of the form (very very small prime) * (very large primes). As you've
> noticed, trial division will do better then.
> Similarly, a space shuttle is not necessarily the best means to travel
> from Paris to London.
> (to factor a 180-digit composite on one single machine, you'll definitely
> need some time!)
>From the README (admittedly not exactly in the place you would look for
it):
Note that it is a good idea to remove small prime factors using
special-purpose algorithms such as trial division, P-1, P+1, or ECM,
and use CADO-NFS only for the remaining composite factor.
Pierrick
