cado-nfs - Re: [Cado-nfs-discuss] Where is a log of completed jobs?
  • To: Mike Curtis <vbcurtis@gmail.com>
  • Cc: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] Where is a log of completed jobs?
  • Date: Tue, 06 Feb 2018 07:41:51 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Mike,
> From: Mike Curtis <vbcurtis@gmail.com>
> Date: Mon, 5 Feb 2018 19:57:05 -0800
> My machine completed a multi-day factorization while I was at work, and then
> rebooted unexpectedly. CADO cleans up the working directory after it
> finishes, so I can find no information about the factors found. Is there a
> log kept in a non-temporary location?
> If not, might you consider a simple permanent log of input number and output
> factors? Better, include the summary CADO presently outputs to terminal when
> it completes a job (time spent on poly select, sieve, LA, overall are
> specific items I am interested in; Q-range sieved would be nice too).
> -Mike Curtis
you already have 2 solutions to this problem:
1) use CADO_DEBUG=true, which will prevent the working directory to be
removed (of course you should also avoid using /tmp/xxx in case you
anticipate your machine will reboot and erase everything in /tmp)
2) launch your cado-nfs.py command inside a screen or script command,
to keep a copy of all its output
Best regards,
Paul
